Dinos is always having good & valid points ( just wanted to say that :) ).
Thing is... I have had corruption as well as some other people here, but even with BIOS v0701 and v0601 ( the 0601 surely doesn't have the "corruption fix" ) starting from the past 2 weeks I haven't had any corruption and I've been pushing the board ridiculously high and outside what most people would even think of.
1.75V SB & NB on stock cooling ( just fans over the heatsinks ) [ changed the thermal paste as well ], 1.8V QX9650 CPU @ watercooling, 2.3V RAM at DDR3-2050+ 7-7-6-21 1T and more.
I wasn't even using memtest to "pretest" my RAM for errors before trying to get into windows and bench or run stability programs & stressing the components :D
It's crazy, because I've had corruption with the v0601 BIOS for sure in the past, and I haven't really changed anything in the system.
Same CPU, same RAM, same VGA, same PSU, same HDD, same Norton Ghost Image, everything.
Even the settings, every setting I use ( successful or not ) is being recorded, so I have "logs" to check back anytime.
The more the testers the better.
If you can separate the testers into categories that might be more effective as well.
Still I wonder how Asus missed the malfunctioning tRFC setting in their BIOSes for the Striker II Extreme ( from some version & all the newer versions ), it just ignores your setting.
Now, if their testers are leaving the sub-timings @ auto, that's not going to help them find the bug, right ? ;)
Manufacturers use their own "weapon of choice"...erm... I meant way to beta test their stuff.
You missed the relationship a bit :p:
Dinos is "helping" Gigabyte :)
But that's not my job, he can speak for himself and I bet he will :p:
Let him get some rest, he had some seriously long flight home.
