Of the four retail Q6600 G0's i've had here, all showed those same marks, as picture above.
Where? www.directcanada.com
When? Sunday, August 26, 2007.
Got a G0.
Anyone have good results from week L726A ?
Just received from www.directcanada.com ---> G0 L726A851. Looking good so far! I don't know how realistic those idle temps are though. I've got good water cooling but room temp is like 25c. :shrug: OC results to follow shortly.
EDIT: not even worth posting. It cant even match my QX6700 B3 3.5GHz 1.45v BIOS quad Prime stable. Nice low temps though! :rolleyes:
Very nice temps indeed.
I feel like DirectCanada had 10 G0 CPUs, because none of the reviews said "i got a b3".
Keep tweaking away man because these thing can do 3.6ghz @ under 1.4vcore.
http://img488.imageshack.us/img488/9...00g0sl1.th.png
Some CPU Power @ 3.85Ghz
http://img165.imageshack.us/img165/7...ndrazv2.th.png
Core #3 keeps erroring out a few minutes into 8k FFT. Tried up to 1.55 vcore which made it the longest but still got an error on #3. Also I messed around with all the relavent settings in BIOS with no joy. I'll try it out an a different board in a couple days.
Is Newegg stocking "G0" stepping as yet?
I picked up a G0 SLACR at frys in san diego(they restocked last week)
L727A968
just playing with it now :D
hmmm...I've got some L726A854's wonder how they'll do compared to the L726A851s posted above.
cheers,
dave
As using old DS4 fsb restricted...but not bad...a 3.5ghz o/c
http://img117.imageshack.us/img117/1...lelargewr2.jpg
I got mine at PCClub in Oceanside, California.
SLACR L727A918
Thank you Zebra for that excellent first post, and welcome to XS.
There are a lot of good deals for a Q6600 showing up everywhere. I.e., you can get a Q6600 for $266.95 shipped @ Buy.com right now.
It would be great if this thread would go back to which it was intended and people would just report where they bought their Q6600, and stepping they got.
Tank Guys, L720B066.
Finally got this Q6600 installed. Initial startup was 3.2Ghz, 8 X 400 at Auto vcore.
Now running at 3.6Ghz, 9 X 400 with 1.45 vcore. Also upped NB v to 1.45.
It runs SuperPi 32M just fine. OCCT passed and I plan on running Prime overnight.
Not a bad start. The thermal paste hasn't even spread out or set up yet.
Temps at idle are a little higher than my E6600, but load temps max out so far
at 60C.
Very satisfied that I waited for Tank Guys to come through!!!!
I just grabbed a L726A849 from TankGuys three days ago but have not fired it up yet, still waiting for ram and new case to arrive.
Compusa... G0 for 299.99 LOCALLY!
Its going to be a little while yet. I still need the case then I will be doing a total new system, this chip is getting a Thermochill PA 120.3 rad and Dtec fusion water block. I would certainly grab a go chip as they all seem to be clocking rather well and at around 300.00 its a great deal and rather future proof.:)
I have the same batch number as flesheatingvirus L726A849 that I got today from tankguys. Right now I am about 1 1/2 hours in running prime small ffts at 3.6 ghz. Voltage is 1.4125 in bios and 1.376 actual under load. Temps are 57c for first two cores and 55c on the other two. I'll post some screens after about 4 hours. Oh yeah and vid was 1.26 something.
Just revceived my q6600 from newegg, Edison Warehouse.
Got the GO L726A854.:D
Any info on this batch??
