Updated onboard Lan driver [posted 20 JUL 2007]:
REALTEK 10/100M Fast Ethernet Driver for Windows 673
http://www.majorgeeks.com/REALTEK_10...ows_d4957.html
Vista drivers:
http://www.majorgeeks.com/REALTEK_10...sta_d5605.html
Vista drivers:
Searched and didn't find anything...
Will the Enzotech Ultra-X Copper heatsink fit on this board?
I haven't heard one way or the other, but I think it would.
I;m able to use my old Thermalright XP-90c with no problems and it uses a 'normal' 775 backplate and I don't have any clearance issues.
Is there a list boards that it won't fit, by chance? If so, that might help you get an idea.
Haven't been able to find one.
Having some trouble installing windows on this board. I get a BSOD with the system in my sig right when i go to enter my product key, sometimes before that.
A problem has been detected and Windows has been shut down to prevent damage to your computer.
PAGE_FAULT_IN_NONPAGED_AREA
If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again, follow these steps:
Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need.
If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use Safe Mode to remove or disable components, restart your computer, press F8 to select Advanced Startup Options, and then select Safe Mode.
Technical information:
*** STOP: 0x00000050 (0x881098E0, 0x00000000, 0x88A0ED9D, 0x00000000)
Any ideas?
After a little research on line it appears to be a memory problem.
Install only one stick of memory into the board and load optimized defaults then try loading windows again.
I have RAID0 setup, really wierd because early yesterday all 4 sticks were running fine on my badaxe2. Ill try 1 stick when i get home from work.
Make sure you are giving them enough voltage to work right.
Tried giving them a little more volts still no go. Tried 1 stick, still no go. Tried with only my raid harddrives, still no go. This is so frustrating.
Did you try a different stick? Try another stick in each slot. I know this is frustrating but sometimes it takes a little finess to ge a board going.
Ok so i guess i wasnt giving enough volts, i thought it was plenty but it seems 2.0 is the starter for this set of ram, thanks guys and now look forward to some results from me!
Seems my xfi is acting up, newest drivers off website dont work, anyone have a link to some that do work?
Hi Circaflex.
Her are some new betadrivers from creative.
http://connect.creativelabs.com/beta/default.aspx.
I haven´t installed them yet myself, but I will later today.
As mush as i love this board, lately i have been taking advantage of the fan control options via the bios, however by doing so i have discovered an annoying high pitching whining noise coming from the motherbaord.
The noise only appears when i surf certain pages (sky sports, heavy add related sties) and even makes the noise when i put on WMP, does anyone else have this problem or now of a cure??
anyway to flash to bios without usb key or floopy? dont have either and want to try the beta, can a cd work?
Yes put that in and it will work just fine.
Will I be able to boot with the Crucial Ballistix Tracer 800's with stock voltage?
i see the 800's up there but not Tracer
With two gigs I booted with mine, 4x1gb sticks wouldnt boot from stock but two were allright, I would try it and find out before you do anything else though just to be sure.
This board overvolts the ram a little bit also so keep that in mind.
Have anyone managed to clock memory above ~610(1220) with 5/6 or 4/5 ?
I tried 2 kits of teamgroup (1200 cl5 / 1300 cl6) with no luck...
i haven't started playing with memory yet on this board but have reached 617MHz (dual 32M SPI) no problem when testing FSB and PL levels:
click for full size including Memset / uGuru...
http://img.photobucket.com/albums/v2...17_pl7_1sm.png
