quick questions did you guys install all those drivers from the asus cd or just disable that stuff in windows?
I'm using the new beta bios on my P5B-Deluxe v1.03gQuote:
Originally Posted by Spacemaster
Just ran the full suite of PCMark05 with all my usual daily background processes only to see if its stable with the designated voltages I have allocated in bios options for my overclock of 3.22Ghz with E6600.
http://i97.photobucket.com/albums/l2...X800XT550c.jpg
http://service.futuremark.com/compare?pcm05=488169
I am not sure how these scores stack up against other P965 & E6600 combos :) keeping in mind I am using my old backup vga card.
Originally Posted by situman
http://www.xtremesystems.org/forums/...d.php?t=117701
is running the vNB @ 1.6 - 1.65 risky ?
Im getting no post at all, the pc is on but no post and no signal on the monitor after running all the tests and SP2004 for over 4 hours....
Check this thread:
http://www.xtremesystems.org/forums/...62#post1747362
I will appreciate any feedback.
It is if it runs too hot. On p5b, you should be able to run pretty high fsb without maxing out NB. I am running 1.65 under crunching load 24/7 for over 3 weeks, but room is cool and I have a fan blowing right at nb.Quote:
Originally Posted by Random
Hi all,
I'm at the moment working on my new rig.
p5b deluxe
core2duo e6400@3280
twin2x 2048-6400c5
arctic freezer 7 pro
2x seagate sata2 320gig
Now I'm testing for system stability with prime95
Which torture test do you guys use?
small ffts, in-place lare ffts or blend?
From what I've read, blend seems to be the best option for Dual Core cpus. Having said that, if you are patient enough, run all three for 8 hours each.
Additionally, with dual core cpus you need to stress both cores, so you either need 2 instances of Prime95 running simultaneously or just use Orthos - this runs 2 instances of Prime95 from the same application.
To find the limits of your cpu, use small ffts as they fit in cache mem and aren't as dependent on ram/nb settings. When your satisfied, run large ffts to stabilize the rest.
The length of time is up to you as prime will stress your hardware far more than you are ever likely to. I have systems that failed prime after an hour or so that I chose not to "stabilize" by increasing voltage/temps and have been running both cores 100% loaded 24/7 for weeks producing double-checked crunching results without a single error. So, for me that's stable enough.
EDIT: fixed typos
Originally Posted by Moonraker™
cool man.... what is the rest of your settings (fsb:ram ratio, etc, etc)? It would be cool if I could see the whole thing, just to make sure I dont have something out of wack with my settings when the new board comes in...I dont wanna fry it again:banana:
Whats the highest stable overclock, I mean stable as in running benchies and not dual primming for ages... anyone has got with 4mb cache Conroes & Asus P5B mobos...?
I don't know how everyone is getting 1:1 ratio on memory. Got the p5b delux, corsair xms2 6400 c4 memory, setting in bios to manual, 4 4 4 12, but cpuid still says it's 2:3 ration...
yes...i had that problem too, and VGA helped. However, I also noticed that rebooting (pressing the hard reset) also did the trickQuote:
Originally Posted by Grinch
exactly! that's what' I've asked repeatedly and no answer yet! :confused:Quote:
Originally Posted by zipdrive
I followed this guys instructions because it seemed to lay it out step for step, this is my first windows install with this system.
http://vip.asus.com/forum/view.aspx?...Deluxe/WiFi-AP
But one thing im stuck on.
followed instructions for AHCI installation {link above}. under the device manager settings it does indeed show two hard drives labeled as
Disk drives
-WDC WD1500AHFD-00RAR1
Under the device manager it also shows controllers as
IDE ATA/ATAPI controllers
-Intel(R) ICH8R/DO/DH SATA AHCI Controller
-Primary IDE Channel
-Secondary IDE Channel
-Standard Dual Channel PCI IDE Controller
Now my problem. Under My Computer it does not show or reflect that i have two Hard drives.
It only shows one hard drive as
(C: ) Local Disk 139GB
Why is it not showing my second hard drive, in the past usually after a fresh install it would show the secondary hard drive and if you go to open it it asked you to format then your good to go. Here i dont see anything to show my missing (D: ) Local Disk.
Can somebody please help me get this sorted out. Id like to start xfering my important files to my secondary Hard drive for storage.
Well im sitting comfortabley at 3510Mhz with my E6600 w/ 1.5125V Bios. Its not prime stable at this until like 3450's maybe a little less but passes benches and most importantly it can take my 3D Renderings very well without an issue.Quote:
Originally Posted by IluvIntel
this is what I am getting now...but still tweaking:
http://s2.supload.com/thumbs/default/bigasstest.JPG
How do i get my second hard drive to show up in my computer? its showing on device manager so i know its there. This is a fresh install btw.
Set your FSB back to 266, then go into mem and select PC2-4300. Then whack your FSB back up to whatever it was. That should be 1:1Quote:
Originally Posted by ssabripo
Just pick the ram speed that's 2x your fsb, which unless changed in a bios later than my p5b, will be the first one.Quote:
Do you see it Control Panel->Admin. Tools->Computer Management->Disk Mangement?Quote:
Originally Posted by ShakeNotStirr
From there, you partition and it should show up.
Originally Posted by eyes.only
Hmm, that was short: My config gave up on me,
Lowered the multiplier to 7 (instead of 8) and pumped up the fsb to 450 to see what this could do, Vcore=1.4, memvolt=2.1. Running memtest and after 2 minutes the system restarted and was continuesly try to reboot. (thought I smiled something strange:confused: ). Cut the power and started it again 10 minutes later, but still no go. System isn't continuesly restarting but starts but no boot, only fans keep turning. Took memory sticks out and tried it. Same problem; system starts but still no boot (even no beeps).
Gonna RMA this, but what is damaged??????
I've got noone where I can test for instance my mem or cpu.
Is 1:1 ratio supposed to be better? If so, in what way?Quote:
My E6600 (334 x 9 @ 3005) runs my ram at 4:5 ratio at 418mhz. I've tried using 430 x 7 @ 3010 so that I could run my ram at 1:1 (@430mhz), this actually produced slower SuperPi-1M times, albeit not by much.
334 x 9 @ 3005
4:5 ratio @835mhz, 4-4-4-12
SPI-1M: 16.921s
334 x 9 @ 3005
1:1 ratio @678mhz, 4-4-4-12
SPI-1M: 17.168s
430 x 7 @ 3010
1:1 ratio @860mhz, 4-4-4-12
SPI-1M: 17.102s
Thanks for the tips, but still no POST. :(Quote:
I've tried:
- both DVIs
- DVI -> D-Sub adapter
- above in both PCIe 16x slots
- an old ATi PCI card with a D-Sub
- no peripherals
- 2 different sets of RAM
- Clear CMOS
- installation in a case and w/o a case
- with CPU fan plugged in (CPU_FAN) and un plugged
- with and without the wireless
- all above with 8pin+ATX24pin plugged
Originally Posted by largon
Hmm, this is all not to good.
What's wrong asus??
Anyone who has had these problems know what the problem was?
I think mobo
