#SAE
i have a hard time belief that ypur GT is -63 idle at 2860 MHz @1,93
some thing like this :
http://www.tweak.dk/forum/attachment...fc51b1827b1b77
we all can make :
MAX so far is -66
#SAE
we all can make :
MAX so far is -66
^Maybe his room is cold :p:
So this is useless to do on DFI boards?
My room is indeed not very warm... then those factory built unit ;) differ in charge and so on... I also have a pic where my new mobile is at -71°C idle at 11.5x257 :D It takes some time. But it can. And additionally you have the stopgrant mode in nb enabled the right way...Quote:
Originally posted by KoGeR|Max
#SAE
we all can make :
MAX so far is -66
I am very sorry if you don't believe me... most of the time with my mobile now it's around -55 to -60°C at 11.5x264 (3024) and 1.93V (vdrop)... load is around -50°C after a while... :thumbsup:
thats a nice system you got there SAE, one of the highest clocked mobiles i've seen, is it 100% stable at 3024 24/7??
#SAE okay... what is your room temp then ?
my is a 2400+ and it is stabil at 3007 MHz 24/7
My room temp's around 16°C atm :)Quote:
I have average temps of -55°C when room temp is around 22°C+
I have a 2600+ at 3GHz+, but with my fsb it's not fully stable (to do prime longer than 1hour, superpi 32m only works sometimes...)
I could do superpi1m at 240x13 though, as well as pifast :cool:
/edit
P.S. I always run my fans on turbo :D
i use 12 x 230 2-2-2-11 but my board stops me :(
what is your fans on then ? 2200 rpm ?
i use 1300 with a avg temp at -50 c
Yeah. Fans at around 2200rpm but sometimes spinning up and down, not really constantly... maybe a firmware update would fix it???Quote:
do you have any "exp." with NF7-S ? i can use :D
Drop me a PM what you wanna know :DQuote:
WOW Sae.. your only 12 marks away from 25k.. squeze that last bit out of your system!
I try I try ... :p:
But I am still trying different drivers... 3.1 were the best ones for me... (I am about trying 3.5, 3.2 and 3.7 :D )
The graphics card is what's holding me back... :(
hi there, i have a question to all those with the XP-M2600+ who passed the 225MHz FSB, which type of cooling do you have? & which vcore do you throw?!
casue i can't pass the 225MHz FSB with my IQYHA, though i reached 12x225MHz @ 1.85v :rolleyes:
11.5x260+ at 2V Vcore... L12 mod, and default wire mod to 1.775V.
not bad! :D using phase change, right?
Yeah. Nventiv Mach2 GT :DQuote:
But it's equal what cooling you use according to the achieved fsb...
The wire mods are necessary for reaching high multipliers with high fsbs stably.
Whats the default wire mod to 1.775v and what does it do (i can guess but wanna make sure)Quote:
the same! :slobber:Quote:
It defaults the cpu from 1.45V to 1.775V. It's one strand of wire in the cpu socket as shown here by soundx98:
http://server6.uploadit.org/files/soundx98-Vcoremod.JPG
Only to do the red one.
thought that'd be what it does but why do it, better stability/higher oc??Quote:
