Now im at 4230Mhz (9*470)
Update on my progress:
Managed to get Orthos small FFT's stress test stable for 73 seconds. (Vista is "stable", i can surf and Orthos Gromacs Core test does not fail)
I lowered a lot of the voltages: (all temps stay below 42degrees C)
My settings are:
Ai Overclock Tuner : Manual
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 470
PCI-E Frequency: 100
DRAM Frequency: DDR2-941
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 18
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time : AUTO
Write Recovery Time : AUTO
Read to Precharge Time : AUTO
DRAM Static Read Control: AUTO
Ai Clock Twister : light
Transaction Booster : Disabled
Relax: 1
CPU Voltage : AUTO //reads in BIOS/cpuz/cpuid: 1.304v
CPU PLL Voltage : 1.50 // 1.58v
North Bridge Voltage : 1. 51 // 1.51v
DRAM Voltage : AUTO // 2.1v
FSB Termination Voltage : AUTO // 1.408v (vdroop?)
South Bridge Voltage : AUTO
CPU GTL Reference : AUTO
North Bridge GTL Reference : AUTO
DDR2 Controller REF Voltage : AUTO
SB 1.5V Voltage : AUTO
I tried transaction relax level 0;no POST, and setting :2 boots but stress test fails after 14seconds :mad:
