Also if you have some settings on your camera, try to put the ISO a bit higher, and the shutter(?) a bit lower, dont know the name in english.
Never use flash, the pictures comes out so sterile.
"Can I get these fittings to work with my MCR-320?
Fittings: http://www.petrastechshop.com/1np1odthhoba1.html
Or will they give me a leaky system? "
I'm in a hurry, so it would be nice with a fast reply. :)
A simple "yes/no" answer would be fine. :)
Thank's ;)
Woah great shot Redeemer!
Thank you :)
Nothing special compared to most of the builds on here :) Still got some cleaning up to do, my cable-fu skills are weak :p:
Specs in sig, and sorry for the bad pics......
Nice case "nick". :)
Lian Li cases are absolutly gorgeus. :)
@ G4H4(insert more uninteligible leet speak): I like the Lian Li build. When I saw those cases, slapping a radiator in the front like you did was one of my first thoughts. How was the install on that guy, was the spacing on the front fans right for a radiator so all you have to do is rip out the front drive cages? Again, nice build.
p.s. How is the dust management on the PC-A70?
Here's my setup:) figured i would finally post it after replacing my motherboard with the DFI X38. thx for all the help and info provided here:up: . i know its messy but its working fine for me right now.
planning on adding my Ultra, and north bridge to the loop but haven't decided on which block to get. prolly wont keep this case for too long need a bit more room.
oh and dont worry about that exhaust fan i just moved it off of the north bridge cooler so you can see everything.
bundy, let's see the whole case mate. We're tired of seeing similar pics every time you post. ;) :p:
Also, your compressions don't match.
ok buddy, letme see, what i can do for ya :D :
http://www.abload.de/thumb/img_0315mul.jpg http://www.abload.de/thumb/img_0323yu1.jpg http://www.abload.de/thumb/img_0330izx.jpg http://www.abload.de/thumb/img_0336rxo.jpg
These are pictures of two different systems ;)
Ah - that makes more sense now :D.
The 2nd last pic also seems to be the same system as the last.
i'm confused do you have two systems bundymania or is this just a revision?
I think its a revision of the previous system, looks great btw
actually, i got 4 systems runnin´atm - Main Sys. -> Aurora: Lian Li G70 (Specs in my Sig.) - 2. Little Devil: (AM2 Sys. , as shown above, mostly used by my girlfriend and for lan gaming etc. ) and an IBM Laptop and an older Surf PC :)
http://www.abload.de/img/img_0358p53.jpg
http://www.abload.de/thumb/img_0362f8w.jpg http://www.abload.de/thumb/img_03630km.jpg http://www.abload.de/thumb/img_03605ny.jpg
Hi guys just reworked my dual loop system as the DD D4 pump i've had for years has finally worn my ears out. I've switched to a single loop catered for quietness.
Heres how it looked before
http://img.photobucket.com/albums/v4...p/DSC01104.jpg
http://img.photobucket.com/albums/v4...p/DSC01106.jpg
http://img.photobucket.com/albums/v4...p/DSC01107.jpg
And heres what it looks like now.
http://img.photobucket.com/albums/v4...p/DSC01109.jpg
http://img.photobucket.com/albums/v4...p/DSC01113.jpg
http://img.photobucket.com/albums/v4...p/DSC01118.jpg
The hardware it's running is getting on a bit now
Asus P5B-D
C2D 6400
2GB 1066 ram
2x500gb HDD's raid0
7900GS
Enermax liberty 620w
Colling kit
Thermochill HE120.3 + 6 Xilence fans
DDC + alphacool top
DD TDX
DD chipset
Maze 4
T line
1/2" clearflex
@dark_redeemer
you could try using a polarizer so that the insides will show up more clearly from that angle. :D
@ bundy
your system seems to be known worldwide :ROTF:
but they are great :worship:
now some pic's of my system :D
http://www.abload.de/img/dsc00649y4z.jpg
http://www.abload.de/img/dsc00650suv.jpg
http://www.abload.de/img/dsc00651woe.jpg
greetz
coolhand, watch that foam under that DDC, could cause the pump to overheat and fry.
