what pump are you using reaper?
how hard was it to get that tubing on that pump? :)
can you show a pic of this?
thanks how is it placed on you pump?
probably with a bit of 1/2" or 7/16" tubing off the pump to the fitting.....
Added a couple of MC-TDX and a refill with Black Feser liquid :)
http://www.coolercases.co.uk/rossi_r.../Stacker_7.jpg
http://www.coolercases.co.uk/rossi_r.../Stacker_8.jpg
http://www.coolercases.co.uk/rossi_r...Stacker_11.jpg
http://www.coolercases.co.uk/rossi_r...Stacker_12.jpg
Wow nice black and yellow :D
I like the two-tone fans, very unique. BTW, Coolermeister what is the white thing under the radiator? I looked at the linked thread in your sig but it didn't really say anything.
Case mod is great, though the hardware is really ugly, the green PCB's :stick:
@coolmiester:
Your Yamaha-Mod and the SLR-Mod are both very very nice :clap:
It is so close to perfection. Just a little more cable-management work and black-PCBs (any sponsors for coolmiester out there? :welcome: ) from your neighborhood and it is a MDPC :yepp: Lots of people recommend your systems. Go for it coolmiester!
[MDPC]dualbrain
New mobo :rocker:
http://img352.imageshack.us/img352/6748/dsc09257fj8.jpg
:up:
Freaking good looking rbsmontemor!
rbsmontemor, i love how you attached the RAM fan :up:
might steal this one :D
Now Equipped with a Thermochill + Shroud and a Nexxxos Extreme III in Top
http://www.lifepatcher.com/pc/ll/hwside5.jpg
http://www.lifepatcher.com/pc/ll/pumpsite3.jpg
looking awesome peebee how your temps now with the thermochill?
Not tested yet. ;) Coming soon! But Idle at same temps the fans run slower than with the Nexxxos for CPU.
