:p: I think they will make you :banana:Quote:
I'm a little uneasy with all the hype over these sticks just to learn that most users are barely recieving any overclocks at all. Great stock sticks, but I had to cancel my order given:
- Micron-F ram is not "limited edition" as original purposed.
- They are expensive compared to sticks that can clock better.
- Many users are reporting SPD problems. (Quality Control or CPU-Z, I'm not sure)
- Misleading results posted by the original poster.
- Exposure of the true Micron F performance by Tony.
Hmm not a very good way to start out. Artificially hyping up the product to increase demand for what is essentially a mainstream product. Giving cherry picked sticks to the reps to test (i'm not blaming the reps, its all on the company's head). Now unless Teamgroup do something to show good faith, they lost a couple of thousand life long customers. Guess where they will go...-> OCZ, Mushie, G.Skill. Good job, good job!
i have the 2x1 gig micron sticks i have a dfi ultra-d OCZ powerstream 520 opti 165 300x9 24x7 stable i use 166 dividder ram at 245 everythings fine at 2.7 volts i go to 180 divider wont even attempt windows 2.8 volts same thing i copied sieras settings any ideas?? thanx in advance
Though I've been reading this forum for years, the only reason I finally registered was to express my total dissatisfaction with the type of hype we see regarding these new 'Super Sticks' we've been seeing lately.
Of course it could be said that running anything above spec is getting more than what you paid for, but I bought the particular ram I have expecting to run well above spec, since that is what all the hype lead me to believe I could do.
I guess I just miss my ballistics! (when they worked)
I've been burned 3 times on 3 different brands trying for a modest (3D Stable) 267MHz. These are the closest I've had to my goal. From now on I think I'll let the hype diminish and let a thread grow (and get some more realistic results) before putting down cash.
I will see, i have a find a german shop should have them soon.. If they don't come this next week i will certainly switch for G-skill 3200 UTT-BH5, I don't need 290mhz right now.. just something around 262-270x12.:D and with CAS2.0 (this will make the job, on the expert my TCCD are limited at 260x12 CAS2.5 )Quote:
Originally Posted by Xtreem Tech
i'm seriously thinking about picking up a second set and seeing how it works out... more out of curiosity than anything :p:Quote:
Originally Posted by Forgotten_Ronin
Sorry, maybe "consistent" results from multiple sources would have been a better choice of words. I'd like to see you work some magic on some week 03 year 06 sticks though :stick:
someone buy my ocz GX and g.skill LE (which will be coming back from rma in a few days) to give me the funds and i'll give a go. sadly, i'm a broke student, hard to pay for a lot of the stuff that i have sitting around :p:Quote:
THis set, not even pass 270 with anything I tweak..Ozzi know that..
now, what did I do? what change I made?
2.62v? lol and look at those timings
during the run took on camera.
http://www.ocxtreme.org/onepagebook/...0/DSCN1763.JPG
before finished:
http://www.ocxtreme.org/onepagebook/...0/DSCN1764.JPG
windows captured screen:
http://www.ocxtreme.org/onepagebook/...fddr55032m.jpg
Did you lower the volts to 2.62 to gain more speed?Quote:
Originally Posted by Onepagebook
no,
actually it is the little factor because:
1. I did this on that PSU
2.try several boards.
3.Play upper divider(233, 216, 250)and Ds/DDS along with Tref
so ram is isolated to running exactly the speed you wanna test.:)
Same here, if i can't find this Team group BH-5 soon here in Europe i'm gonna go the Gskill road even though i think the Team will clock better.
reminds me of my old motherboard... :(Quote:
3-3-3-8
2.5v - 276.25
2.6v - 272.46
2.7v - 271.7
2.8v - 269.43
2.9v - 264.14
was the max stable 32m :stick:
http://www.xtremesystems.org/forums/...ad.php?t=93529
THis also make "a lot of difference":D
:slobber:Quote:
i need to replace my 420w powerstream one of these days... :fact: :D
update i am up to 270 so far on these sticks super pi stable....:banana:
Settings? :)
Same here for both my kits, I left everything on Auto/default and was large FFT stable up to 270 @ 2.7V.Quote:
Originally Posted by leo5111
After 270, the fun begins :D
Still working on 275 ATM :)
Originally Posted by Zeus
Yeah i give you this shop link, normally they ship in all europe areas..
http://www.overclockers.de/prodlist.php?kat=267
Ok... you can see the DDR are not avilable yet, but they think have them in something like 10days..perhaps more
In wait i take the part to buy G-Skill 3200 UTT BH5, for take some fun with them and i will have now different good memory for have resource for test and tweaks with different chips..:D
i used sieras settings exactly except for dram drive strength mines on weak 4
have you given the suggestions i gave you a go? :toast:Quote:
i will when i try and crank it up but for now seems stable with settings im usin thanx though ozzi....:toast: :toast:
I've made an excel spreadsheet composed of almost everyone's stable settings and all I can say is...damn! There are very few similarities from system to system so I would have to say that these sticks are just trial and error until you get lucky basically. At everything set to auto on my current rig I can't get any stability whatsoever, yet others get up to 270 before running into problems. This is one heck of a learning experience to say the least!
