Is PSU holding me back ?
Kinda worried cause +12v line is so low ?
http://img151.echo.cx/img151/8448/pic13uz.th.jpg
Yes but I see that you have isolated the tube properly, so I guess that the condensation from the source of your cold is finsh :)Quote:
Originally Posted by coop
I think that on the mobo you can use only foam, for sure ;)
How is above 12 volts on the 12v rail low? :p:Quote:
Originally Posted by TEDY
dunno at 317 or 318 when i try S&M 1.70 quick 100% load PC reboots , why ?
maybe temps too high ?
did u ever thought of ur ram holding u back?Quote:
Originally Posted by 0g1
shutdown when temp is above xx°C (maybe you filled this in bios)
That can be your problem :)
Because of burning in my 2700mhz stable at 1.45V moved to 1.376V :D
There is also an amd 64 bit driver for windows. Some say it helps with oc'ing.
nah i set it to 65°c hehe
Nah, i think i took that out of the equation when i set HT (ie LDT) to 2x, used 100 divider, and also put the ram timings to SPD. Of course, its not like that in the screenshots, because I was already sure of my max cpu speed before increasing the memory/HTT speed.Quote:
Originally Posted by babyelf
try a 2X LDT multiplier..
has anyone use 0519 week?
hehe
latest results
317*9 rock stable at 1.45*110% = 1.595 (1.54 cpu-z)
http://img60.echo.cx/img60/5339/prime3172zk.jpg
THat's not a low 12v whatsoever ;)Quote:
3000+ LBBLE Venice 0516GPEW
Prime/Superpi/OCCT stable @ 300x9 2.7GHz 1.57v Watercooled
yeah...want to know as well. doesn't seems to be a good week but since i've yet to see any result on this 0519, i'm not quite sure. i'll be receiving mine this couple of days. was hoping to get week 17 but no luck :( . probably the full code will be :Quote:
Originally Posted by kosmonova
ADA3200DAA4BP
LBBLE 0519DPBW
Z649096E50124
is it any good, guys? :idea:
remysix try it :)
This CPU seems to be the sh*t so far... 2.7GHz @ 1.38v primestable for about an hour, after that it completely froze though... Haven't had any A64 CPU *freeze* on me because of instability, only reboot, bluescreen or simply error in prime95, so I'm not giving up on this yet.
Anyway, 2.7 should be easy now :D
yay broke my personal best 16M and 32M times
http://www.fileshosts.com/DFI/NF4_SL...16m_twk_tn.jpg
http://www.fileshosts.com/DFI/NF4_SL...rpi-32m_tn.jpg
3000+ LBBLE 0516 GPAW
not fully stable but hey :D
yeah, happned to me, up vcore a bit, I went from 1.38v to 1.45v and it stopped freezing. Its strange it dosen't error out but just locks. :stick:Quote:
Originally Posted by exscape
it's own its way. will have it this weekend. just checking if anyone has any idea on this stepping. :cool:Quote:
This is my 2nd LBBLE 0517 DPMW... First one had batch ~900 and this one has ~300. First one could do 2.6G @ 1.46v, 2.7 not 100% stable even at 1.65v.
This one seems to be primestable @ 2.7, 1.41v.
If my point isn't clear; CPUs differ, a lot. I wouldn't be surprised if I got this baby to 2.8 stable.
i got a 3000+ Retail coming from newegg today, hoping for one of those 3 lucky numbers.. 12 / 15 / 17
redline 4000 and a dfi nf4 as well, ill be posting pictures real soon..
here is mine:
LBBLE 3200 0515FPBW batch0016 from Spain ;)
http://perso.wanadoo.es/dave_338/prime2650.JPG
If I up volts to 1,55 full temp goes too high and system crashes badly, seems that 53-54ºC is the maximum for overclocking this proc.
I'm trying tu push a little more with minimum voltage adjustment.
amd 3000 venice
ada3000daa4bp
cbble 0512dpbw
1229488c50073
http://users.telenet.be/duploxxx/oc/...9%20166dev.JPG
on air 2963 @1,58-1,6vcore bench stable will try a bit above 1,6vcore thats the max i will try
duploxxx
Guys, need to know what you think, I've lined up a buyer for my 0516 EPKW. I called a local shop, they have one 3000+ Venice left in stock, and it's an LBBLE 0517APJW. I haven't seen an APJW, but the rest of it (APxW) under the 0517 date seems to be leading to VERY nice overclockers...should I be able to expect nice results out of this thing? I need to know ASAP, i'll probly do it, but I've got high hopes already for this thing.
you won't know until u try it.. most 0517 is already good.. even with a good stepping like xPMW or so u might still get average clocks.. i have 3 and only 2 are really good
one doing 3ghz one doing 2.95ghz one only 2.8+ghz
all 0517 DPMW
