cheap as chips :)
cheap as chips :)
sorry.... i forgot to post it here :slap: my bad... i got a modded bios for this board
13 Guru-R1
1. Update NVMM to version 4.94
2. Update NVRAID to version 4.84
3. Update NIC to version 212-0487
4. Update Boot Up Logo
5. Add DDR 366 Memory Divider
Download Link:
http://www.tictac.katrourke.com/modu...p=getit&lid=42
Source:
http://www.tictac.katrourke.com/modu...ownload&cid=22
great
what happened to DDR300 divider ;)
were you able to do anything about Venice and 1T issue?
Originally Posted by tictac
I reckon admin needs to drop off some of the stickies and include this as one....it is clearly very popular by the amount of posts, views and how current this information is....i wonder if that will get done :toast:
hey, i just recently ordered these rams: G.Skil Pc4400 = http://www.newegg.com/Product/Produc...82E16820231006
but ive been hearing bad things abt this board with tccd and venice :S
i orderd an8 Sli (non fatality version)
so did i screw up real bad :s
ya this board need Clawhammer + Winbond UTT :banana:Quote:
Originally Posted by desolator
there is no DDR300 divider on abit bios... :shrug:Quote:
Originally Posted by dinos22
not sure about 1T issue with this new bios
seriously? dont scare me man, im only a 16 yr old kid, it was hard enough arranging for the money, n i screwed up d'oh!
*kicks himself for not sticking with dfi*
nah... just make sure you set it to 2T.Quote:
if i am 16 years old kid... i will get this combo :hehe:
TwinMOS UTT 512mb x 2 : USD39x2 = USD78
http://www.newegg.com/Product/Produc...2E16820218405R
AN8 ultra : USD133
http://www.newegg.com/Product/Produc...82E16813127212
3500+ Clawhammer : USD267
http://www.newegg.com/Product/Produc...82E16819103514
My board runs good with venice... what's people having trouble with?Quote:
I run (right now) 9x300 with 333MHz divider (memories running 246MHz) with not problem at all.. (thou i only run 2x512MB right now, cus one of my other 512MB's was broken).
is it on 1T timing?
Thanks for the modded bios tictac :toast:
Please post any issue here... ;)
As soon as my ultra arrives ill be flashing to that bios. :toast:
tictac, why did chose NVMM version 4.94 over 4.052.08 and NIC version 212-0487 over 212-0491 ?
Yes it is on T1 timing.. tou right now i only run 288MHz HTT w. 333MHz divider. Also i should say that i'm running on the 16 beta bios.Quote:
dang I want your beta bios dude...looks like it fixed that 1T issue
Originally Posted by Rolle2k
Some people are having the same trouble as with the 15 bios (sli won't work and so on). send me a pm with mailadress and i'll send it to you.. but i ain't responsible if something goes wrong.
you've got a PM
did you ever have problems with 1T...say official bios 13/14/15
dinos22
Well my board is dying and im itching to fire up my an8 ultra so i think ill take this tired board and give it one more big bang and put it under DI before i RMA it. what do ya say should i do it? hmmm i smell a new htt and memory speed record :P
Push it till it cooks! New HTT record would be cool.
From the beginning my board did have the 13 bios.. i put in all 4x512MB running 2T (of course, 4x512 cant run 1T). But i had som trouble, erroring in memtest.. so i flashed the bios to 16 beta directly, now the 4x512 did work, but i couldn't clock anything, if i did it just error directly... but i then discovered that one of my memories was damaged. so i haven't flashed back and tried 1T on 13, cus the 16 beta works flawless for me.Quote:
I can run my TwinMOS PC3200 512 MB (UTT) modules on DFI nF4 SLI-DR @ 255 MHz with 2-7-15-2-2-5-2-2-1-1 1T no problem (3,5 V)
Abit Fatal1ty AN8 SLI system shuts down if I try to run SuperPi 1M @ 215 MHz with 1T! 200 MHz - 210 MHz works fine with 1T and 2T runs ok at 253 MHz.
Using offical 1.5 BIOS from Abit site.
yea for some reason Abits has a hard time with winbond chips. I got a set of OCZ gold with BH die and it wouldnt overclock for crap even with 3.55volts. It just powers down.
I don't understand why you're having such problems, i have the same chips, and i OC:s good for me... strange..
