Originally Posted by ***Deimos***
Hey SikaRippa,
long time no see,
I've recently done the Vmem mod again, after getting a little itchy to do some volt mods (TP13-TP14). Also, for a long while, pretty much regardless of clock speeds, memory seems to cause problems.
XFX 6800 Rev2 16/6 + NV5
Autodetect is quite low. I flashed very loose timings, and 1.4V (1.33V measured). Although I can set, and run 3DMark2005 as high as 414/950 it occasionally 5-30min "glitches". During benchmark or whatever 3d, the screen flickers, and suddenly its like its running at 75% speed. I have forced performance level enabled, and fastwrites off (enabling even at default clock speeds = havoc)
After voltmod (default 2.72V), 2.85V, max on memory still about the same... up to 978 in ATItool for 5min+ without artifacts, BUT internal driver test, coolbits or rivatuner fails even at 790.
Could it be wrong Vddq, or other memory voltage parameter. I tried capacitor mod before but had very limited results... not sure what the problem could be. I could measure whatever points you need....
