well ive never seen a dos based cpu tester b4. i remember some french site wanted to make something called cputest86 but it never got released?
:D Ah, SRY - now I got You - talking about DOS based....., hm, is there any advantage compared to the windows based versions?Quote:
Originally Posted by P_1
:toast:
not corrupting your hd? ;)
are there indee so many ppl havin trouble? i didnt try much more than 300, but 9x300 was working flawlessy...Quote:
Originally Posted by HARDCORECLOCKER
maybe some people got the non fixed fubarred boards? :down:Quote:
Originally Posted by goddh0r
Got a board from the latest shipment arriving today and it came with BIOS Jan 25. Revision is still A01. Unofficial word is that even the boards from the first shipment last week has been implemented whatever changes necessary. That's why there was a 2-day delay in getting those boards out last time.
Updated with BIOS 1.31 and performance is at least on par with 1.26. Managed to run FX-55 at 10x290 and 9x320 with 1.6v vCore and finished typical benchmarks - SuperPI and 3Dmarks. So far, it's running great with no instability problems at all. :)
Link: http://premium1.uploadit.org/WaterGun//9x320s.JPG
marquzz over @ techsweden.org has a beta board (i think, he atleast has a SLI-DR) and he tested 400fsb and it worked perfect, so is it the newer cards that can run high fsb or is it the review samples? :confused:Quote:
Bios embebed apps are a good way to test OC if you are near the hardware limit. Running these apps without booting into windows can prevent you corrupting the OS. It also saves time as you don't need to wait until windows boots each time you get BSOD :banana:
Still waiting the reply from bytesatwork :confused: Can't wait anymore
:brick:
Coluld someone test wich mem dividers are causing problems?
Bios embebed apps are for newbs. We've been overcloking for years without it, do things the old fashion way and just overclock like your supose to. Overclocking isn't for everyone!Quote:
Originally Posted by Bourch
OPP
Nice put OPP ;) Guess have to wait untill everyones here put their cpu on this mobo..
:slobber: Anybody remember this (#70):
BETA sample MOD ???
:toast:
What your saying doesnt make sense. How does using embedded apps make one a newb? :rolleyes: With an embedded app you can test your ocs quicker with no risk of corrupting your hd. This saves the trouble of using a spare hd to test your overclock. With an embedded bios you can start testing your oc's much quicker, therefore making the overclocking proccess more efficient. It doesnt make overclocking easier at all, one still needs to know what they are doing, you cannot just say "OOOOOO I HAVE AN EMBEDDED APP IM A SUPER OVERCLOCKER NOW"... no it doesnt work that way, embedded apps are just tools for overclockers it doesnt replace experience, just makes the proccess smoother for people that know what they are doing.Quote:
Originally Posted by OPPAINTER
Yes it does replace experience.:DQuote:
Overclocking takes time and patients. You need to check for both your Max CPU speed and your max mem speed and get it right, and this needs to be done in small increments.
You don't just throw a bunch of numbers in the bios and hope for the best.
OPP
Who said anything about using random numbers? And if you do use a bunch of random high numbers the board just wont boot and in the worst case(some tard that uses 4v for their ram and 2.1v for their cpu by "mistake") fry their hardware. So in the end it still doesnt replace experience. If you dont like embedded apps, OK. But several other people, including me, welcome this feature.Quote:
Can your little app do this for you, I don't think so.Quote:
OPP
13x267, OCX VX at 2-2-2-5
http://www.xtremesystems.org/forums/...id=23729&stc=1
LOL... I'm waiting for the day when 3d mark 2001 is built into the bios, and using advanced algorithms, will know excatly what your score will be before you even run the benchmark.Quote:
I get embebbed apps like an aditional resource with helps in some situations. I will use them for quick tests in the begining, until I familiarize with new hardware limits. Once I am on the good way, back to prime stress and 3dmark loops. Anyway I don't see them as a replacement to the old fashion methods.
I wish to speak a more rich fluid English an of course with a richer vocabulary :(
:mad: O.K. - enough is enough - come down guys - this is not the place to win a boxing championship..........
:toast:
Oskar already install it in 1-31 bios... maybe some1 should ask him how to execute the program :toast:Quote:
Code:CBROM V2.07 (C)Award Software 2000 All Rights Reserved.
******** nf4ld131.bin BIOS component ********
No. Item-Name Original-Size Compressed-Size Original-File-Name
================================================================================ 0. System BIOS 20000h(128.00K)12ABCh(74.68K)NF4LD131.BIN
1. XGROUP CODE 0E9A0h(58.41K)09E6Ch(39.61K)awardext.rom
2. CPU micro code 01800h(6.00K)0024Ah(0.57K)CPUCODE.BIN
3. ACPI table 05E71h(23.61K)01F7Fh(7.87K)ACPITBL.BIN
4. YGROUP ROM 0F760h(61.84K)0465Ch(17.59K)awardeyt.rom
5. GROUP ROM[ 0] 07BF0h(30.98K)032E5h(12.72K)_EN_CODE.BIN
6. Other(40B5:0000) 02140h(8.31K)00CE4h(3.22K)_ITEM.BIN
7. OEM0 CODE 021C0h(8.44K)008FCh(2.25K)BSMICODE.ROM
8. PCI driver(A) 0C000h(48.00K)064B3h(25.17K)NVRAID.ROM
9. PCI driver(B) 10000h(64.00K)07B05h(30.75K)NVPXES.NIC
10. PCI driver(C) 0F000h(60.00K)071FBh(28.50K)r5_5137.bin
12. OEM1 CODE 00090h(0.14K)000AFh(0.17K)MemSetup.rom
13. OEM2 CODE 14628h(81.54K)07F69h(31.85K)MemTest.rom
14. OEM3 CODE 14668h(81.60K)0827Fh(32.62K)CPUTEST.rom
Total compress code space = 5C000h(368.00K)
Total compressed code size = 52831h(330.05K)
Remain compress code space = 097CFh(37.95K)
** Micro Code Information **
Update ID CPUID | Update ID CPUID | Update ID CPUID | Update ID CPUID
------------------+--------------------+--------------------+-------------------00000000 00000000 0039 0048| 00000000 00000000 003A 004A
00000000 00000000 0041 0150|
:D Hey OPP - we all know and respect Ya fantastic record - but everybody had been a beginner once and nobody's perfect, do You see ?Quote:
BTW - more interesting if the board You use is a stock one or a BETA sample MOD, can You clear it up ???
:toast:
Well, while I'm at it:D
This mem test thing people use, whats up with that:D
I've never used mem test in my life, never will. They should have left that app in the memory Labs. I hear people complain about not being able to pass mem-test all time.
Who cares about mem-test, I sure don't need it.
Alright, I'm done complaining about these Overclocking apps now:D
OPP
:D I agree - especially because memtest is not a real help for me - got it error free but rig didn't boot at all so something's wrong with it.Quote:
Can You answer the question depending Your board?
:toast:
DFI Boot Up logo :toast:
http://www.xtremesystems.org/forums/...chmentid=23753
Well then beginers should read the "How To Overclock Guide 101" then. Like most of us did.Quote:
I have no Idea about my board. I can tell you it doesn't have the final mods on it though, they are supose to send one of those to me this week.Quote:
The board I have here runs great, rock solid, 4V mem works all that.
OPP
thats nice! :slobber: :toast:Quote:
Originally Posted by tictac
