The truth is that all cases made by Coolmiester are beautiful, especially CM Cosmos mods looks crazy ;) GJ
amazing rig coolmeister. Think i've seen it before, or maybe it was another of your great builds :up:
Here's my new custom build. Soon to have a worklog posted. Wish i had money to upgrade but i don't so i just rebuit my stuff into my good old Stacker but i did some lil mods to the case so it could fit it all. Liquid colors are really horrible and not what i wanted them to look. The kind of pink was supposed to be Fire-red as labeled on the dye bottle... and the pale green one was supposed to be Visible blue also as labeled on the bottle... Whatever. Anyway, so here's the result :)
http://i242.photobucket.com/albums/f...atriote203.jpg
http://i242.photobucket.com/albums/f...atriote206.jpg
What you guys think, other than the horrible colors?
EDIT PS: Yeah, i went from that bulky U2-UFO to that case. Quite a change let me tell you. I've been having my U2-UFO since 2 years now and god was it taking a lot of space on my desk.
Few more pics of my new build with flash off ;)
http://i242.photobucket.com/albums/f...e/IMG_0598.jpg
http://i242.photobucket.com/albums/f...e/IMG_0601.jpg
http://i242.photobucket.com/albums/f...e/IMG_0612.jpg
http://i242.photobucket.com/albums/f...e/IMG_0616.jpg
http://i242.photobucket.com/albums/f...e/IMG_0618.jpg
http://i242.photobucket.com/albums/f...e/IMG_0619.jpg
http://i242.photobucket.com/albums/f...e/IMG_0620.jpg
still want to say...
chage the pink one lol
I apologize for the blurry pics.
http://i183.photobucket.com/albums/x...h_DSC01002.jpg
http://i183.photobucket.com/albums/x...h_DSC01005.jpg
http://i183.photobucket.com/albums/x...h_DSC01006.jpg
http://i183.photobucket.com/albums/x...h_DSC01007.jpg
http://i183.photobucket.com/albums/x...h_DSC01008.jpg
http://i183.photobucket.com/albums/x...h_DSC01009.jpg
http://i183.photobucket.com/albums/x...h_DSC01013.jpg
http://i183.photobucket.com/albums/x...h_DSC01019.jpg
Black Pearl FTW.
Upcoming changes: Going to be moving to Crossfired 4890s, so the top MCR240mm rad will be moved down to the bottom chamber along with the RS360.
coolmiester lush pc you got there matey!
YMAA, are you sure there is no aluminum in your loop ? Your reservoir looks like it has a nice cloud of galvanic corrosion leftovers floating at the top.
looks very good due, great build :up:
is that a Zalman Fan Controller?
No, there's no alu. It's just been a while since I've washed it, since there isn't really a way to scrub the inside of a MicroRes. Pretty sure it's just a calcium deposit or something, nothing to worry about. Res will be getting washed the next time I take the loop down, though.
http://i169.photobucket.com/albums/u...o/IMG_0693.jpg
http://i169.photobucket.com/albums/u...o/IMG_0694.jpg
Pretty much the only pics I have that isn't fuzzy or distorted, not bad IMHO since I did it with rattle cans. The back looks WAY better in person, the gloss orange does not play well with the camera flash. The black expansion slot guards and I/O plate gives a nice contrast with the orange back. If I took the picture without flash the orange ends up looking like a orange/red :-\. Anyways I did this mod cause i'm heading off to Clemson University this fall as a freshman and I needed a case that not only represented some school pride but was easy to recongnize if it got stolen from my dorm haha :-p
Anyways that was my first case painting job and i'm fairly happy. In the rig is a home-made CPU block, MCP655, BIP II, and swiftech microres.
Here's some photos of my rig:
http://img.photobucket.com/albums/v4...design_052.jpg
http://img.photobucket.com/albums/v4...design_056.jpg
http://img.photobucket.com/albums/v4...design_061.jpg
Still an ongoing project though....
Some changes: painted the inside black, changed the tubing, coolant, and fans.
http://i88.photobucket.com/albums/k174/Fish99/325.jpg
http://i88.photobucket.com/albums/k174/Fish99/324.jpg
http://i88.photobucket.com/albums/k174/Fish99/323.jpg
http://i88.photobucket.com/albums/k174/Fish99/321.jpg
Rumpus01, that blue coolant/tubing looks awesome and matches the HX1000 really well. Great job!
thanks guys. the case is a cosmos s which i think looks infinitely better with the inside black. I went from 1/2" tygon r3603 to 1/2" Feser tubing, and it is the most amazing upgrade ever. this tubing is just simply amazing. No kinks in the least, thick walls which made it super easy to fit over the noryl barbs on my pump, plus it just looks damn good haha. it's really clear. as for fans, i'm using the two black stock fans that came with the cosmos s, they're really quiet and good looking, and then two other black ones that came stock with my old case that I replaced, so they haven't seen much use at all.
i would like to introduce myself to the u.s community
http://www.abload.de/img/img_952145l1.jpg http://www.abload.de/img/img_9514fl4u.jpg
greetz from germany
Finally got activated, my first post. Been lurking for a good while now and the XS forums helped me a lot in putting this together.
http://farm4.static.flickr.com/3369/...fdd0083d_o.jpg
http://farm4.static.flickr.com/3308/...815cd5b0_o.jpg
http://farm4.static.flickr.com/3368/...1b4bacc0_o.jpg
http://farm4.static.flickr.com/3628/...933ab845_o.jpg
Q9400, 4Gb DDR3, XFX790i Ultra, Quad SLI GTX295. Gigabyte Odin Pro 1200W
Swiftech MCP-355, XSPC res top, Koolance VID-NX295s, HWL BI GTX420
HAF932 in White. :)
Well here's mine, I'm not the best at taking pictures but here are a few shots that I liked....
Windows Vista Ultimate x64
Intel Core 2 Quad Q6600 @ 3.6Ghz under H20
ASUS Maximus Formula SE (NB under H20)
4GB Patriot DDR2 800 Ram 4-4-4-12
Sapphire Radeon 4870X2 Under H20
NZXT Khaos Case
3x Raptor X 150GB HDD's
2x Samsung 300GB HDD's
500 Watt Antec PSU
700 Watt Kingwin PSU
http://i282.photobucket.com/albums/k...g?t=1247614056
http://i282.photobucket.com/albums/k...g?t=1247614085
http://i282.photobucket.com/albums/k...g?t=1247614103
http://i282.photobucket.com/albums/k...g?t=1247614229
I figured I'd throw these in here... fantastic for music and gaming (surprisingly) the bass is.... rediculous
http://i282.photobucket.com/albums/k...g?t=1247614263
Awesome NZXT Khaos mate :up: too bad it's not available here in Europe, was eyballing that case for WC purpose and because it differs from all the TJ07's and stuff. Big enough to accomodate a quad rad vertically inside...nice.
very nice NZXT case :up:
Done a few new mods to my lian li *cough*.. rocketfish, re located the power switch to a new one on the top. and wired up some rocker switches.
http://i151.photobucket.com/albums/s.../DSCF4585m.jpg
http://i151.photobucket.com/albums/s.../DSCF4589m.jpg
older pic here
http://i151.photobucket.com/albums/s...itled_HDR5.jpg
Nearly finish my first water case:
Lian Li P80
- i7 920 @ 3.8
- Dominator GT cas 7 1866
- Evga gtx295
-Enermax Rev 1250W
+ Heat Killer 3.0 & Koolance gpu block & Enzotech NB
+ Premochill 360 x1, Swiftech 240 x1
http://i327.photobucket.com/albums/k...g?t=1247861776
http://i327.photobucket.com/albums/k...g?t=1247861826
Cheer :)
basic black man I like that, good stuff kuti
