I see you put up your 3rd place 2x 4870X2 killer 3dm06 run Chew*! Great work! :clap:
team usa will be good :D
i wonder how team greece will do...they got animals :D
Heh that was Msimax and myself ( combined effort ), he deserves credit to, I think he has a PI 1m submission of his own to put up.
Hopefully I can improve some results in the next few weeks :)
On a side note we hit the 7300 mark today. Lets push that further guys.
wooo awesome job you guys...7314pts :D
linuxfan also overtook me :D ....this is good :D
i'm still finishing my winter water cooler ... hopefully soon..
i'll mount this on my porch...outside temps are at 1c right now.. :D..i'll use 100% radiator fluid for zero slush :D
http://i24.photobucket.com/albums/c5...5/NewImage.jpg
Testing a new i7-975 right now, passes 3dm06 at 4915 MHz under single stage :D a shame it coldbugs at -60° C :( with my luck even a Phenom 965 C3 will probably be coldbugged.
That's why I need to grow some benching discipline - I'm missing too many points just because I didn't have proper OS or certain benchmark installed at the time...
Too bad I can't submit those huh :p: :ROTF:
http://database.he-computer.de/Bilde...rime_Tyan2.jpg
xoqolatl,
I sort of had the problem to, here's what I did to break it.
I have 2 installs of XP ripped, 1 vista and 1 win 7.
Initial testing I do on phase before I break out the more volatile stuff.
Once I have ballpark cold I use 1 xp as a sacrificial lamb, find the max bench of all benches, jot them down then can the OS that most likely got corrupted finding maxxes and start benching the fresh installs per OS biased bench. :)
Benches are all installed on a seperate drive save a few things that need to be on OS drive, such as bits and peices of vantage and 06 and cpu-z 1.52X, this allows you just to drag shortcuts over to all OS's.
Hope this helps.
We should chat somewhere more privately on AMD benches :)
This sounds good! What mainboard are you on?
Haha, finally! Thanks mate, you gave me something to smile about for the whole night! :up:
Top 5 Global WPrime is great! Those results will give some serious points once Gulftown is released!
Thanks chew :up:
Problem is, I usually don't have enough time to switch OSes during benching. I rarely have a whole day for benching, more like 2-3 hours a time, and in that time I usually fight with clocks not with software. I'm trying to do serious benches when I have time to prepare everything. All results I am really proud of have been made after long hours of sitting in front of a monitor, listening to rotary compressor... nothing good ever came from short sessions of benching in a hurry. (yes, call me captain Obvious :D )
As for AMD benching, there are a 965 C3 and a 790FXT-UD5P here that are begging to be frozen :D but it'll be at least a week until I can arrange "something volatile" as you call it.
EDIT: I'm on Classified 760, with 1,575 volts real
So most likely no chance to go higher with another mainboard... :(
4.9 GHz on an i7 is not that bad anyway, just do as many benchmarks as you can. With your 5870s you could gain some nice points in 3D. ( 05 + 06 ) Good luck! :up:
Just don't forget there's a single card category as well! ;)
Update: broke 30k in 3dm06 with a single 5870 :)
This is just testing the CPU on SS, real benches with dice, Crossfire and hopefully a better CPU are incoming.
EDIT: oh an watch out Linuxfan, I'm aiming to be the 1# of all people using my sig template :ROTF:
I saw your new scores in your profile, a single 5870 is almost as fast as 2 4890s, with an i7 at almost equal clocks ( ~4.9GHz ). Those GPUs are so strong! :shocked:
Good luck for your PCMark 05 runs!
As long as the US is in front in this round, it's all good. I'm afraid Germany will not score very well this time. :( I hope that will change next round, I will do my share in the AMD stage ( depending on which benchmark has to be run. ).
You should be able to get your golden cup back later on, at least as long as no one gets his Q9650 under LN2.
Something I really like about this competition are the short stages, the pros can't select dozens of processors and test them under LN2, this leaves a fair chance to normal guys on air that have excellent processor already and have done their homework with their gear. :up:
Linuxfan, I told ya this would happen:
http://www.hwbot.org/signature/u13804.png
Now get benching before I fly out of your range :D :ROTF:
Today was a good day!
http://img94.imageshack.us/img94/106...ovember7th.jpg
xoqolatl still going strong with his i7 975 and his HD 5850, chew* is still running his Athlon II X4 low-budget setup, Xtreme_Solid is pushing a Core 2 E2200 and a Core 2 E7200 and Zucker2k managed to get the silver cup in the Q9550 SPI 32M category.
Last but not least the fourth XS team member has posted his results for the HWBot country cup. This time it's PcCI2iminal who is benching for Brazil. The other three members are thebluemeanie1 and Jor3lBR, both are benching for the US, and andressergio who is competing for Uruguay. Jor3lBR is also currently the no.2 in the Q9650 SPI 1M category. :up:
That was just the pre-testing :)
Stay tuned for more points after database refresh :D
EDIT: My fresh results just got ranked:
http://img410.imageshack.us/img410/643/hwbot7112009.png
Mostly single GPU benching with HD5850 and HD5870.
I am especially proud of PCMark05 and both Aquamark results, as I have never benched those before. PCMark05 was done on two Intel X25-M 160 GB gen2 drives.
I had a serious problem with Aquamark at first - scores were in range of 260-270 k. When I figured what to do to get proper scores I literally jumped from joy :D
Those were not ranked when I took the screenshot. This is insane! Those are some fine scores! :up: :up: :up:
AM3 is my favourite 3D benchmark, and the only 3D benchmark I like too... :D
Please shoot me a PM what you changed! direcpll?
You pushed the team's score to 7375.4!
http://img20.imageshack.us/img20/596...ovember7th.jpg
Does someone have results worth ~40 points as backup? This is the perfect time to post! :up:
