Mine won't pass 223 for anything in this world (i'm on air). I'm 99.5% sure it's my vga holding me back.
i canīt pass 223 too. i think it is the cpu...
I've just traded in my P6T V2 in for a EVGA E760 but i'm having some issues getting to the same stable overclock I got with the asus. I previously had a 24/7 overclock of 21x213 with 1.3625v and everything apart from ram set to auto. the classified settings i'm running at the moment are
Voltage Control without v.droop
CPU VCore: 1.375
CPU VTT Vcore: +300
IOH PLL Vcore: 1.45
CPU PLL Vcore: 1.500
QPI PLL Vcore: Auto
DIMM Voltage: 1.65
IOH Vcore: Auto
IOH / ICH / I/O Voltage: 1.675
ICH Vcore: 1.050
VTT TWM Freq: 250khz
CPU PWM Freq: 940Khz
QPI Signal Comp. : Less
CPU Features
Turbo on
HT on
CPU Clock 20x
CPU host 210
MHC Auto
CPU Uncore AUTO
CPU Clock Skew 0ps
SpreadSpectrum Disabled
PCIE Freq. 105mhz
vtt looks high to me
EVGA X58 Classified (E760/E761/E769) last bios
S61B Updates:
* Restores Bootup Logo
* Maximum Payload for PCIE
* SMART Fan Temperatures from 0 to 100C
BIOS updating can be accomplished VIA the below methods:
http://www.evga.com/forums/tm.asp?m=...1&key=�
Juse ended up getting my New Classified 3 way in the mail yesterday, I have not even tried overclocking the beast yet, hope to see what I can achieve with this, over my old UD5
I just got my classified installed last night and today I am trying to overclock it somewhat, I am having some trouble with the voltage settings using E-leet and even the BIOS, they are not being entered in correctly, or the read outs are wrong, my DRAM for example. I set it to 1.66V in BIOS and in E-leet although, the monitoring tab in E-leet shows DRAM at 1.72V and even HWmoniter shows the same read out. I also notice it with my QPI voltage, the VTT in BIOS is set to say +250Mv but in the E-leet read out I am getting 1.52V and then in another place I am getting 1.42V, so it is weird to have 2 different reading for a single voltage even using the same program...
http://img.techpowerup.org/091007/volt.1.jpg
http://img.techpowerup.org/091007/volt.2.jpg
Any ideas classified owners or anyone? I also ordered a new set of the Kingston Hyper X 2000 Mhz RAM the cas 9 timing one,not the real expensive kit, any news on how these clock and how tight you can get the timings on them?
Checked my volts with dim last night. Eleet monitoring is way of here (crazy high VTT/Vdimm). All volts (idle and load) were within 0,01v of what is set in bios.
@ Jakethesnake011, start with 1,30v for QPI and work your way up from there, 1.45v is not needed in most cases on Evga (or you must be running very high memspeed/uncore clocks).
lol
:eleet:
Got my 2nd spot back with this run,
http://i33.photobucket.com/albums/d61/200sx_/709.jpg
My rig pic...
http://i33.photobucket.com/albums/d6...7102009632.jpg
:D
What memos areb these? Red Line?
Hi,
this is my first x85 board so im still learning :) .
im having a weird problem, when i restarts i can hear a noise coming from the board until the the post stops checking, it stops before booting into windows it only happens when restarting not when i turn it on after a shutdown .
should i be concerned about it ?
please ignore, it turned out to be the GPU.
Jakethesnake011 forget monitoring softwares, u have all Tension misuring points there,try a multimeter :up:
when i set lower than 1.65/1.35 Vdimm/Vtt board don't drop
if i set higher than drop like 0.1 in idle and 0.2 in full load with 760 and latest bios
Hiwa buddy i have E760 now :)
if u still don't flash ur mobo, please do it soon, my E760 fly with last bios
i am really happy with this main, this is the first time i don't change mainboard for more than 3 months, really no need anything and look like great with I9 too, benched with over 100h lol and still works like a charm.
+1 latest bios is great, faster boots. The board just seems tighter. with b2b settings mem clocking almost feels like cheating!
S61B you guys mean? Stil using A here.
S61B yup
i have a ? i'm thinking of getting this board but i need to know if i can run 2 4870x2's in it?
Yes you can
COOL thanks
