My first i7 920 D0 stepping cpu and bclk wise, it has alot of potential on plain water. Although, vcore wise it's a mixed bag > http://i4memory.com/f80/first-i7-920...results-17703/ heh.
http://fileshosts.com/intel/DFI/DFI_...m_10s374ms.png
http://fileshosts.com/intel/DFI/DFI_.../cpuz_idle.png
want to see the fastest i7 920 on the planet courtesy of Windows 7 and CPUZ flakiness during Hyper Pi 8x 32M Pi test ? How about 12200Mhz - 61x200bclk LOL
http://fileshosts.com/intel/DFI/DFI_...m_8x_12200.png
Update: interesting the vcore required for HyperPi 8x 32M PI test might be just for that, as I started testing Prime95 small FFTs 1hr stable at 20x200 = 4000Mhz at 1.312v and Prime95 Blend custom 5.4GB test at same 1.312v and it's running without problems. So HyperPi 8x32M Pi test might come down to memory/voltage related settings. Will try lower vcore after the custom Blend test and then LinX.
You guys should try HyperPi v0.99b 8x 32M pi test to compare against your prime95/linx runs ;)
HyperPi v0.99v download link http://nx.i4memory.com/hyperpi/hyper_pi_0.99b.zip
