yep i have been doing 1066 with 4 dimms populated 2 x 2gig and 2 x 1 gig, all running at 2.1v dimm, and stack vcore on CPU and CPU NB, i had to add .1v to my CPU and CPU NB for my 9850 to take 4 dimms, even then i would get the odd BSOD
I have issues running 4x2Gb too. Memtest fails at 1066. Down to 800 now and testing from there.
Tried NB up to 1,5v and RAM up to 2.28v with no difference. My CPU/SB temps are very nice but need to check ram temps.
Thats a great clock, and one of the better CPU's, only thing small FFT's dont stress the northbridge of the CPU.
At least with my current Phenom, the difference in clock speed with regards to stability comparing small FFT's to large FFT's can be as much as 150mhz...........
what is your guys max trc in bios for phII?
This is what I've achieved so far :)
CPU Model: Phenom II X4 940
Stepping: CACVC AC 0850DPBW
CPU Frequency: 3700MHz
CPU Vcore: 1.4875v BIOS (mobo overvolts to 1.50v idle, ~1.52-1.535v full load)
NB Frequency: 2000MHz
HT Link Frequency: 2000MHz
Memory Frequency: 800MHz 4-4-4-12
Memory Configuration: 4x1gb
Memory Ganged/Unganged: Unganged
Mainboard: ASUS M3A79-T Deluxe
Cooling Type: Thermalright HR-01 Plus + 120mm @1200rpm (ambient temp ~25º)
OS: Windows Vista SP1 x64
http://i472.photobucket.com/albums/r...75v_M3A79_.png
Well I spent most of the day seeing if I could coax more CPU out of this CPU, but I cannot. I didn't bother going down to 2 sticks because I want to run with 8gb memory. Even if I push the system to FSB 244 it is not stable (3.66GHz CPU). It's "close" at that point. I tried backing off the FSB to DDR2-800 with the same timings that work at 960MHz, and tried to push the CPU up to 3.7GHz but it was not stable, even with 1.6V on the CPU and 2.6V on the other BIOS setting (that starts with 2.5V, I forget the name!) Just to be absolutely sure I am going to keep it at 3.6GHz on the CPU, 2.4GHz on the NB, with 1.4V and 1.3V respectively as stated in my signature. Memory was also not stable up past DDR2-960, looks like I found all the limits I can, and will just have to be happy with it. I was really expecting more though.
How's this for a glory shot w/ stock volts? Stable enough to get a screenshot! =o)~
http://www.overclock.net/gallery/dat...STOCKvolts.jpg
Normally have vcore at 1.536v but under high load my motherboard drops voltage a bit (.016) and after 10+ mins of occt at 1.52v (even thow it should be 1.536v) computer will restart:mad:. Only have it at 1.568v for occt. Edit: NB is at 0f (1.375v) Also cpu is on water.
http://i380.photobucket.com/albums/o...table1hour.png
guys, how does one validate his voltage? lol.
Yes!
I think I solved my BSOD issues:cool:
There seems to be a hotfix for the 0x00000124 BSOD's which will be in SP2. It's some issue between multiple PCI(-e) cards or so:shrug:
Anyway, what Ive done past days is got my RAID card working (I had to enable SATA controller in BIOS?), fixed BSOD's and got a stable OC:cool:
Ran 6h Prime Blend last night without errors, did a 10 run Intelburntest where the 9th run shown instability, all the other runs were good. I assumed this might be the IMC so changed it to 15 and did a 15 run after and no errors at all.
Maybe Ill give it another try in a while but for now Im more than happy:cool:
I do not have one for that particular speed. However, just messing with the multi I have one upto 23x. Although, I found there to be much stability to be gained by keeping the multi low and the bus speed high, which was what I was playing there to see what I would need for a high cpuz run! Now, it's time for some volts and some bus speed!
http://valid.canardpc.com/show_oc.php?id=482422 Just Multi.
I thought that there was supposed to be switches in in CPU-Z that would let you post the Vcore.
