That ring thats ferrite on the corsiar PCI-E just cracks off the wires... I squeezed it with my wire cutters very lightly and it broke into two pieces
I have such rings on my Antec Signature, overall it is very good psu, but stock sleeving and this rings are terrible. And I don't think it is filters :shakes:
I've not tryed to remove them yet.
Awesome thread!
Some sleeving I did :
http://farm3.static.flickr.com/2516/...c5ee78eb_b.jpg
http://farm3.static.flickr.com/2659/...fa42a22c_b.jpg
http://farm4.static.flickr.com/3466/...db288d51_b.jpg
Short SATA Cable and Curly SATA Cable :
http://farm3.static.flickr.com/2621/...f8cee2ed_b.jpg
http://farm4.static.flickr.com/3649/...ed77eb52_b.jpg
http://farm3.static.flickr.com/2630/...cbc67c01_b.jpg
Short SATA power modular cable I did for my Corsair PSU :
http://farm3.static.flickr.com/2487/...7e0c2cdc_b.jpg
Very beautiful shots and cables :)
Watch out that the SATA data doesn't get corrupted due to all the twists :D:D:D
Anyone got any ideas on how I should sleeve this connector that is attached to fans for my rv-02.. its a little mini fan controller.
http://img25.imageshack.us/img25/278/img00006z.jpg
Certainly learned a lot from this thread.
Hopefully I can share something that worked for me.
Well first of all, those molex extractor tools didn't work for me, I have the Corsair HX520 and the pins are an ass to remove.
http://farm4.static.flickr.com/3426/...fb070072_b.jpg
They need to be made of Adamantium or something, someone get Wolverine.....
These worked best for me (credits to dingdong555 :) ), plus they are dirt cheap, less than 50 cents :
http://farm3.static.flickr.com/2503/...937af2af_b.jpg
I had an extra tool as well, something to help me pull out the "super hard to remove" pins, couple bucks down at ACE Hardware :
http://farm3.static.flickr.com/2640/...04caed60_b.jpg
They have no sharp teeth, so they don't "bite" into the PVC and tear it if you squeeze and pull too hard :
http://farm3.static.flickr.com/2669/...db63ed36_b.jpg
Ok a little demonstration of how I did it :
Get your tools ready :
http://farm3.static.flickr.com/2481/...d5e3af76_b.jpg
(sorry can't resist the shot :rofl:)
Put on your gloves, it does help reduce injury when you yank the cable out, trust me, you WILL cut yourself (maybe I'm just clumsy)
http://farm3.static.flickr.com/2497/...c4a364b1_b.jpg
Push one pin in until it can't go no more :
http://farm3.static.flickr.com/2469/...3852bdbd_b.jpg
Push the other pin in and make sure it's aligned, so you know it went all the way in :
http://farm3.static.flickr.com/2674/...b3f67806_b.jpg
Then just simply use the tool and yank it out
http://farm3.static.flickr.com/2447/...17ecc523_b.jpg
Done!
Thanks Dangals for starting the thread, Guys who contributed (too many to mention), Charles and Nils for the best sleeves ever!
I'm kinda addicted to sleeving, but I just have 4m left of the 1/8 lol
Christian: It's always great to see outstanding sleeving photos :)
Love the glove-shots :D
Here some orange from me (it kills every camera sensor - it's unphotoshopped):
http://www.abload.de/img/orange-mdpc-xsw9v.jpg
Thanks for the mini-guide, hcristain. And, excellent job on your sleeving!
Love the orange, Nils.
Man how does everyone get the heatshrink and sleeving cut the right length? I seem to be wasting heatshrink because it is too short and the sleeving because it is too short too. Any tips?
hchristian Love the shots man! haha, the glove.
Mediocre sleeving at best, can't seem to get the sleeving at the right length for all the cables. I noticed the cable length varies for each color.
I can't see the orange thing :(
Don't flex the sleeving? cause it kind of "pull back" after you extend them.
I use about 2 cm of heatshrink for each cable, worked well for me.
lol, simply couldn't resist it
Thanks for the pin idea! Awesome piece of thing, plus it's harder and doesn't break :D
Here's a trick I use for getting my heatshrink lengths right - cause I just can't seem to cut them exactly the right length (tried to figure out how to use some type of paper cutter to do it, but can't quite see how to do it that way).
First, I cut a bunch of heat shrink pieces - 1.5-2.0 cm depending on how long I want it. Then I check their lengths by putting against something straight - e.g. the box in the pic. Then I trim as required to get them just about right. Of course, keeping the lengths right also requires care when you actually apply them.
http://shazza53.smugmug.com/photos/5...94_wM9Jx-M.jpg
Sometimes you still miss a bit - see the upper most wire in this set. If it's really bad, I will actually remove the heat shrink with an exacto and redo. Some guy around here has this "No Compromises" saying ...
http://shazza53.smugmug.com/photos/6...69_LQNcB-M.jpg
Now that is a sleeve job! perfect length!Quote:
Did you trim the length of the wires? Mine seem to come with different lengths, hence the mess.
A little tip: instead of yanking the wire out of the connector with a pair of pliers, take a very small flathead screwdriver and gently push it out from the same side as you put your needles/staples in. This way you avoid pulling the wire out of the metal piece, like i did on one ocassion. :(
Wow, the look is wonderful!
I am wanting to buy a few meters to in my source and the tools to make the changes, but I wonder if the staff sends to Brazil if I order!
thanks
Has anyone attempted to sleeve their USB keyboard or mouse cords? Maybe even speakers wires?
Heck how about ALL the wires behind their desk?
:D
:) ... sorry ... nothing fancy. It was just a f/3.5 lens, but long thing. No idea what it was, but nothing special :)
Anyways, I told a good friend (Ferhan aka fhantastic) to finally register here at XS. Since this might take a while he allowed me to now show some beautiful sleeve-art that he did. Will be cool once he is registered here!!!
Here we go :D
http://img1.abload.de/img/dsc03218p1vd.jpg
http://img1.abload.de/img/dsc03217y2ai.jpg
http://img1.abload.de/img/dsc0321546te.jpg
http://img1.abload.de/img/dsc03216o3te.jpg
Sleeved on regular cables of course: No tape, no tricks, just extremely good sleeving by an extremely good sleever :)
Anyone know how to remove the sata power connectors from a HX1000W PSU? I want to customize the length. That guide on Page 1 doesnt help
