Official BIOS Release v12
http://www.itsjohnnybravo.com/Overcl...T/M704B_12.BIN
Should be up on the abit site very shortly ;)
i flash the new v12 bios but no improvement in term of max fsb :D havent tried other though
still max at 470 i think its similar to b09
I think it's just the B09 "cleaned up" for Public use ;)
Will inquire when abit HQ starts work tomorrow again ....
with bios 12B09..........nice....
http://img168.imageshack.us/img168/1885/41712201al4.jpg
http://img258.imageshack.us/img258/7386/01vo6.jpg
My RMA replacement is finally coming in today. Nice to see I'll have a shiny new BIOS to play with too! :up:
Finally...! The version 12 final BIOS is out.
Gonna try this sweetie real soon. Thanks Brother Johnny. :)
Can someone please check the bios ref in main bios page after flashing to official 12.Myself & another guy who flashed are showing 12.09 i' just downloaded from your link johnny & reflshed & see12.09 ??
cheers:)
@Supershanks : yes same me to...I flash new Final realise 12 from 12B09 stiil showing 12B09 in bios page...
apparently it won't be "rubber stamped" until abit puts it on the website :rolleyes:
Thanks Hazzan & Johnny :up:
Still it worked better today:lol:
The new official BIOS is up on abit site today... :)
BIOS: m704d12.zip
Bios Issue Date:2008/01/02
Mirror Site: ASIA Europe US
BIOS ID:12
1. Fixed Command rate function abnormality.
2. Fixed DRAM Timing abnormal.
3. Update JMB363 ROM version.
4. Fixed twice boot issue.
5. Enhanced Intel 45nm CPU compatibility.
6. BIOS compiled date: 01/10/2008.
I wonder what twice boot issue this BIOS is referred to, as I don't have any double boot issue at all since the first time I use this board...
Naw it 12.09 :lol:Quote:
Interestingly enough johhny's right i noted the complie date of the file johnny sent & complied fdate there was 01/10/2008. Spooky he :D :up:
didn't know owt about that:)Quote:
luck:)
Edit: It still says 12.09 in main bios page:)
Talked to Johnny Bravo last night & he confirmed that the multiplier was ok in 02 for Qx9650 but is broken in all subsequent bios.I'm running q6600 go so can't say
Does this new BIOS now allow > x9 on the QX9650 CPUs?
According to user Galdeano from the German HWluxx forum, upper mults do NOT work with final 12 and QX9650. Too bad...
OK, guys, I need some help. Hooked up my new replacement IX38 today, and about 3 seconds after power on, it turns off. It does this in an infinite loop until I kill the power. I've tried everything I know, going to 1 stick of RAM, triple checked the power connections, removed the RAID card, no change. Is this mobo DOA?
:cussing: :dammit: :censored: :upset:
Update: Tried a brand new PSU and got the same problem.
well isn't that funny. final 12 says it fixes double boot. after flashing to final it double boots :down:
never had the problem till i flashed to a bios thats supposed to fix the issue for some.. also when i change the multi it will go through a weird double boot up. It boots changes the multi, then shuts off then boots with the factory fsb with the new multi. this didn't happen with the first Bo9 bios. they probably didn't change a thing.:D
fixed the problem! went back to beta 8 lmao
Naw... if there is no Fan on the CPU fan header it just shuts down for good (doesn't reboot). I know that problem 'cause the fan i attached to it starts below 300 rpm - had to disable that limit :D
these few days ive got problem with the 90 bios code...
after i install wb on my vga it give me 90 and then i change with other vga but still the same 90 also but it boot by it self n give me c1....
then i change the memory all kind of config...still c1
then i take out the proc..put back n whala its on again...
but after a random restart some time it give me 90 again...i think the bios stuck or what?my easiest solution is take the psu supply at mobo,clear cmos n it can back to normal....
it with bios 12b09
out of interest what is the system spec?
