Same divider, but different strap (333 vs 400). The strap determines what tRD can be set to.
Reporting my results with this memory with a P7N Diamond (signature has full details of system).
4GB:
2.2v, 1050, 5-5-5-15-2T, 45 (tRC)/52 (tRFC)
8GB:
2.2v, 1018, 5-5-5-15-2T, 45/52
1066 is unstable at 8GB with those settings. 1083 is unstable at 4GB with 2.2v, 1050/1066 with 2.1v. Rock solid at the settings listed above, though. This fits the typical profile of G.Skill in my experience - tends to overclock at least a bit, but has a very definite envelope of settings. Not disappointed in the least, especially at this price, and I'm surprised it worked so well with this board in the 8GB configuration.
me and my buddy were on the phone working on his tonight,we were able to get 9800MB/s read and 8200Mb/s write on everest with a 54.1 ns latency at 5/5/5/15 - 1081mhz 2.25volts
Has anyone ran this at DDR2-900 Cas4 2.1v successfully? Im having problems running them at this speed:
Q9650 @ 450x9
DRAM Frequency: DDR2-1081
Dram Clock Skew CH1 A1 : Normal
DRAM Clock Skew CH1 A2 : Normal
Dram Clock Skew CH1 B1 : Normal
Dram Clock Skew CH1 B2 : Normal
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 55
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Write to PRE Delay : 14
Read to PRE Delay : 5
PRE to PRE Delay : 1
ALL PRE to ACT Delay : 5
ALL PRE to REF Delay : 5
DRAM Static Read Control: disabled
Dram Read Training : disabled
MEM OC Charger : disabled
Ai Clock Twister : Moderate
Transaction Booster : Manual
Common Performance Level [8]
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHA PH3 Disabled
Pull-In of CHA PH4 Disabled
Pull-In of CHA PH5 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
Pull-In of CHB PH3 Disabled
Pull-In of CHB PH4 Disabled
Pull-In of CHB PH5 Disabled
DRAM Voltage : 2.118v
But im running it stable at DDR2-900 at all the setting above, but changed this:
DRAM Frequency: DDR2-900
Common Performance Level [10]
Thanks in advance!
Powerchips don''t like 900 MHz Cas4...maybe 850.
bump* (sorry, I know I'm late to the party but this is the ram I just bought and there is a wealth of information in this thread. Didn't want to lose it before I was finished)
Glad that this can still help people. :up:
Hey ENJOY, would you be willing to help me out a little? I must have read this thread at least twice. But there are some things I'm still confused about.
Ok for instance......@ 996 MHZ, (everything auto in bios)
I can pass memtest all day long. Same at 1003MHZ.
< it's my chip, q6600>
However, if I set the memory manualy in bios to 1066mhz, everything else auto, memtest fails at test #7 I believe.
If I set it manualy to 1066mhz and then manualy set the volts to 2.10, same result. Fails memtest.
Any suggestions? Haven't even begun to ask about timings yet. Lol.
ok, i'm not trying to be funny here........did you mean post my questions HERE, or the link in your sig (current) :shrug:
Cause if you meant HERE, I did ask my question. Why is it I can't pass memtest @ manual setting of 1066 mhz with manual setting of 2.1 volts in the bios.
Again, sorry for being late but I've read this thread (all 28pages) twice. :shocked:
I believe "EnJoY" meant to post your questions here. :) It would be helpfull if you made a signature with your Hardware listed in it, will be easier to field questions that way. Also, quite a bit of the PC8000 ram will Not do 1066. Mine won't for instance, so you may be asking for too much out of it.
Larry
Quote
"If I set it manualy to 1066mhz and then manualy set the volts to 2.10, same result. Fails memtest."
See now, with the signature I could tell what board your on, the above quote is part of the problem. The Asus P5Q series boards overvolt a bit. 2.1v set manually to the ram is more than likely giving it about 2.18. Maybe try 1.96 to 2.02v for the dram voltage.
The other part of the problem is that the ram may not do 1066.
Larry
When I posted my reply, you had not yet edited your first post with the question (my post 4:30PM, your edit 4:31PM)...therefore I was telling you to post your question here in this thread. ;)
You're problem is uncertain at this point for several reasons. Basically, you have not given us enough information.
What divider are you running? What speed is your cpu running at when you try 1066, and are you sure it's stable at this speed?
Two suggestions:
1. Start at 1.9v and test 1000MHz, stock timings. Should pass.
2. If you have truly read all 28 pages of this thread, you should have seen several screen shots from various other members in this thread that detail the memory timings used to achieve certain frequencies. I NEVER recommend using AUTO for your timings, because you don't know what sub timings are being applied in this case. With ALL memory, adjusting and tweaking the sub timings are a necessity when trying to squeeze additional speed and performance out of your sticks.
I suggest you re-read this thread and examine what other people are using for their sub-timings with the P35/P45 chipset and this memory.
Once you have your sub timings set, let us know how 1066 does and what those timings are.
Yeah Enjoy, as I was typing my "edited" version, I was thinking that you may have already read just my original request for help. I'm sorry. Like I said, I honestly wasn't trying to be funny or in any way trying to be hard to get along with , with my second post to you.
(^ the only reason I bring this up is because.......for whatever reason.....I seem to find a way to ALWAYS come across to people IRL as well as forums as being somewhat dickish. I'm not that way at all. I just have a knack for coming across that way. :shrug: I've learned to accept that fact, even though it's far from what I am really trying to portray)
To Big.....yeah, I know, posting my system specs was/is a critical factor of information to have if I expect help. To not post it to begin with , especially in my sig was just a bone headed oversight on my end.
To Enjoy. Yeah, I promise you, I have read this thread twice. Let me back up just a second. This may clarify some things for ANYONE wishing to help me.
Enjoy, some of your questions I can answer, some I cannot, because I just don't know. (ie still confused)
I look at you guys as die hards. <not a thing in the world wrong with that, and THAT is why I come to you, the experts> We all have our indivdual talents. PC overclocking is not one of mine. (BBQ is :up:)
So in my mind, my world, I'm a small fry in sea of sharks here at XS.
When you say divider...........? I don't know. I don't know what that means.
Sort of. The only one I really understand is 1:1. As soon as you go past that...I'm lost.
Yes, Enjoy, I could / have looked at the screenshots.....and I have no doubt I could set up mine the same way. The problem with many of the screenshots I have seen is comments made before the screenshots........for instance:
"Ok, here's 4:5 running 5-5-5-12 @ 1.9 ........may as well add "while in a crescent moon stage, and low tide"
I cringe at what I am about to say because I fear it will come across "wrong" again,,,,,,but I don't care about that stuff really. Sure, I can set up my timings just like theirs, and do some testing. But the thing is, when it's over, I have the test results, but have NO clue what they mean. Is Higher Bandwidth better than lower bandwidth? Is faster read/write times better than lower? I realize there is a 99% chance this board (XS) was probably not the best one for someone like me to come to. < XS rocks, I'm just old now, and getting older fast) I was late to this party. Most are moving on to newer sockets and i7, and I'm just now coming to p45 and quad, from a 1.4 T-BIRD.:shocked:
The learning curve this go around has been HUGE for me. Anway, Enjoy, I honestly cannot say if my CPU was overclocked or not. I don't remember.
So, If I may be so humble.......maybe if we could just start from scratch? I undersand the very basics. On one side you have your CPU and FSB. You can overclock just your CPU via FSB. Then on the other side you have your ram. (won't even go there on vid card) (yet:p:)
The CPU / FSB side of the coin tends to be easiest for me to understand. However, I'm using stock intel cooling. I'm worried about heat. So I decided to lay off that aspect of the overclock and just see what my mem can do sinec I have read that for the most part, heat is not an issue with this set.
Tell you what guys. I'll go back to step 1 with the CPU. I'll set CPU at 333X9
which is 3ghz. I'm ok with that heat. So let's test that first. Ok? Here's what I'll do. I'll leave the CPU voltz on AUTO for this innitial overclock.......and then test using Prime 95 (ok?). With each pass of P95, I'll lower the juice one step at a time until it starts to fail. Then I'll raise it up 2 notches and test again. It should pass. Until that time , I won't report anything else...
My only question now, is what should the ram setting be for this? Manual? Auto? And at what MHZ? Fair enough?
Ok, lots to cover here.
I am not going to type up an entire introductory guide to overclocking for you here, as I simply do not have the will, nor the time.
First rule to remember though. Whenever you are trying to overclock one part of your system, you first need to remove the other parts from the equation. This can be difficult at times, but generally it's quite simple.
Here is an example of what I am referring too...
Say you were trying to determine your maximum fsb speed? You would want to drop your cpu multiplier to something low (I generally like 6x), set all voltages to stock (not AUTO), and memory timings to defaults. You would also want to set a memory divider that was very low, 1:1 ratio would probably be ideal and work fine as with DDR2 and DDR3, you would have plenty of overclocking headroom with the FSB before you even reached the stock speeds of most of today's memory.
From there, you would simply go up 5-10mhz at a time, testing for stability at each increment, moving up again until you hit a wall. Once you've hit the wall, increase the appropriate voltages, and continue moving upwards. Generally when clocking fsb and cpu, I prefer using windows based utilities as it is a lot faster. This way you can quickly bump up the speed, jump into super pi or prime95 for a few mins, and keep going until you error out, then back into bios to adjust the voltages. Understand?
Testing CPU, you would follow the same process, but in this case you would simply set the highest multiplier available to you, and adjust fsb up from there. Assuming you tested fsb limits first, you now know exactly what fsb frequencies your board is capable of and therefore it will not be a factor as you increase mhz to determine the limit of your cpu. And of course, your memory is on a low divider and isn't going to be anywhere near it's rated speed at any point in this testing process, so that is out of the picture as well.
Once you have the max frequencies for both your fsb and cpu, the rest is easy. You now know the limitations of both your chipset and your cpu at every voltage step along the way. Now you can set these at safe limits, and if needed, adjust them along the way as you overclock your memory, knowing that neither of them are a factor in your system's stability. To start, set your cpu to a low multiplier, drop fsb to something like 250 or 300MHz, to avoid hitting a wall too soon. And set a divider that makes sense for the memory frequency you wish to start at.
Typically, I always had my best successes in tweaking memory when I started from a very low frequency, testing lower latencies. For example, for this ram, I started at 750MHz, with maybe 4-4-3-10 timings and 1.8v? And from there I would just into memtest and see if it's stable. It is? Great, how about 1.7v? No? 1.75v? Yes, cool. So 1.75v is now my starting point. 4-4-3-10 is stable, how about 4-3-3-10? Or 3-4-3-10? No, ok well then I guess I'll stick to 4-4-3...but how about 4-4-3-8? See what I mean? It's all meticulous trial and error until you find the sweet spot. Once every is stable, you bump up the frequency, 5mhz at a time until you hit another wall? And voltage should always be the first remedy to a wall, if voltage fails, you no it's not a voltage issue but a timings issue, so you go back and adjust the timings.
This my friend, is how we overclock; or at least how I learned to do it. Some may disagree or have other methods, but these methods have always served me well.
Sub-timings are the tricky part these days, however. BIOS' these days can have so many options available for adjustment that it could literally take you weeks until you found the perfect timing combination for your RAM. This is why for you and many others I simply recommend the lazy man approach, and copy off a fellow forum member. See what other people are running for their TRRD, TWTR, TRFC, etc etc, as well as the primary timings and frequency they are running. If you are at 560MHz 5-4-4-12 and you're looking for the right sub-timings, it's probably not a safe bet to copy someone else's sub-timings who is running only 450MHz and tighter timings. Remember, the appropriate timings and sub-timings will change as the frequencies change and as the other timings change around them. As an example, the appropriate TRAS is basically always decided by what the first 3 timings are set too.
I'm already written way too much now, but this should be more than enough of a guideline for you to use to get started.
:up::up::up:
Got it! THANK YOU, Enjoy.
1)FSB.
2)CPU.
3)Memory.
Picked myself up a thick notebook today and some pens. Time to start testing.
I found that connector you were looking for
Cindy, is this the thing you were looking for?
www.liangdianup.com/computeraccessories_1.htm
It's on the list of computer accessories and parts. They have the DVI video thing to convert that jap monitor to work with your other computer. Just about any other kind of wire adaptor, usb connectors, monitor extension wires, ps2 extention wires, and all kinds of female and male swap connectors and things that I think would help your shop. If that above link don't work then goto www.lducompany.com and click on computer accessories. Let me know if that is what you need and give me your email address again.
Enjoy
When you say you like to use windows apps to tweak your CPU and FSB and voltage....if I am reading it right.....you are talking REAL TIME changes, within a single instance of the windows evironment. (ie no changing and then restarting, but changing and testing)
Then when you have it figured out to your liking, THEN you sort of hard set those numbers in BIOS. Correct?
May I ask what application you use to do this?
Not voltage, just fsb/cpu.
You set voltage is bios, head into windows and use Clockgen or a similar utility to up fsb in small increments, quickly testing each one for stability. And yes, once you have a stable setting, you head back into bios, set the new MHz, up the voltage again, head back into windows and continue clocking.
clockgen is available at www.cpuid.com
I just got a set of this off Craigslist for $25. Guy was running it in a hackintosh, so hadn't been OC'd. Have to see what i can get them to do with a P5K premium.
Got it. Thanks again. I'm going to work backwards though. Since I already have a ball park # in my head of my CPU speed, and FSB, ......
^(Read, I don't have the proper cooling yet ;)
I'm going to shoot for CPU / FSB stability @ 3 GHZ with a "set" memory timing.
Like you said, If I have a set memory timing like 800 mhz or 900 mhz, then in theory, knowing this particular memory can easily handle that , it SHOULD take the memory OUT of the picture.
Then I can work backwards, testing for stability, while slowly decreasing my voltage to the CPU, and thus lowering heat. Seems to me it's now just a matter of finding the correct voltage to run my CPU @ 3 ghz. stable.
Once I have done that, then I can focus on tightening memory timings.
Thank you again, Enjoy for your help. I know what I just posted is probably everything anti-overclocking and how to do it, but I already said I'm not much into benches, screenies, or the like. I'd rather be playing, surfing, or rendering in Poser. Anyway, I'm pretty sure I have it now.
3ghz doesn't sound all that hard to achieve for a q6600.. nor does it require high volts. You should do fine
