Stock cooling ftw heh...Quote:
Originally Posted by Cooper
:stick:
a mate is lending me a gigabyte gcooler pro, so that should help :)
:stick:
d@rkn1ko isn't the E6600 multiplier 9x?
too hot :( in france :(
Whats the consensus on the best Northbridge cooler for this board?
KITT - Is the vdroop horrible or manageable?
Set at 1.3815v in BIOS and under load, easy tune reports 1.34v, and CPU-z reports 1.328v....Quote:
Originally Posted by ScottFern
I think CPU-z is more accurate...
It's not horrible...but it's not that good either....
It's an ES, this has been answered several times.Quote:
Originally Posted by BottomsUp
I just test the max fsb for the moment :toast:
anyone know whats the max FSB stable with DS3 and Conroe E6600 using multi x9 ???Quote:
Originally Posted by d@rkn1ko
thnks
That would be nice to know as I getting the E6600 too.Quote:
Originally Posted by mascaras
400 FSB
jesus guys you peeps need to read thru these threads instead of going to the last post and asking these things this sh|t has been answered dozens of times already in 5 different threads
and if you read you'll learn a thing or two about this board and how to set it up with various cpu's.
yeh , we already saw that with low Multi´s (x6,x7,x8) the DS3 can run high´s FSB , but we also know that with multi x9 they are not so good , so anyone can see what the Max FSB stable with a Conroe E6600 and multi x9 ??? I apreciate , thnks again.Quote:
Originally Posted by badboy
I think it's fair to say that 450 x 7 is stable:
http://img.photobucket.com/albums/v6...enprime-07.jpg
Although temps are starting to get VERY hot. Almost dangerous.... (notice the warning sign)
With a relatively low vCore (~0.05 above stock), You can see why i hate stock cooling :rolleyes:
Are you guys using any chipset cooling or do you have the stock one with fans blowing on it?
it has all been said in the last 3 pages ;)Quote:
Originally Posted by celerity
I am also about to order a e6400 and this mobo :)
But because my system still user ddr1 mem and an agp card i need to get some new ram and another videocard too.. and i'll just add a new harddisk too while i'm at it...
in other words; triple_A is gonna be broke for the next couple of months :cool:
nice i wonder how my water will do.Quote:
Originally Posted by K.I.T.T.
Any chance of comparing the overclocking abilities of the DS3 vs P5W K.I.T.T.?
ie: Max FSB
Its seems the mobo is not the limiting factor, but the CPU is. So with higher multipliers you begin to run into problems with the core of the chip itself handling the high total frequency.Quote:
Most likely Cooling will be the limiting factor here and not mobo FSB speeds.
seems my board's max is around 490fsb Super PI 1M
that's with stock vcore air cooled
mch +0.1v
vdimm 2.4v 4-4-4-12 1:1
can probably take a screenshot at 495-500 fsb but that seems to be about it
This is with a E6300 and 7x multi
ArcTan, what's your max FSB when running prime stable? Thanks
I've only tried 461x7 small fft's for about 12 hours though no screeniesQuote:
Originally Posted by nop
Thanks ArcTan. 3.227 is very good for me. BTW, yours E6300's ES,so around 3.0-3.1 should be achieved by retail one...??
hey misteroadster did you ask gigabyte to give us 4:3 divider........... :)
better to wait for retail cpu's before we can say that's true. I can hit my boards limit before I even have to increase my vcore from stockQuote:
This is interesting, Conroe not as dependant on dual channel as the Pentium 4
http://www.matbe.com/actualites/1389...-dual-channel/
