whats a good crossfire motherboard thats decently priced?
with good cooling that`s no problemQuote:
Originally Posted by BottomsUp
ASRock Sockel 775 ConRoeXFire-eSATA2Quote:
Originally Posted by boomheadshot45
http://www.abtron.de/shop/catalog/pr...oducts_id=7972 / 73 euro
Asrock 775XFire-eSATA2 Sockel 775
http://shop.norskit.de/nit/default.a...CK775110026825 64 euro :)
edit : new review of the gigabyte dq6 / http://www.legionhardware.com/document.php?id=572&p=5 . :stick: max fsb = 333 mhz
it seems results is a bit unstable about DQ6 ....
Ok, i'm back from Italy :)
First post updated
Core Duo 2 heatsink / cpu fan group test : http://www.bit-tech.net/hardware/200...up_test/1.html
Originally Posted by Skyline GT-R
Awesome thanks :D
Which is the best mid range mobo for Intel Core 2 Duo E6600???
gigabyte ds3 , 500 mhz fsb :D , cheap
Thx, changed it ;)Quote:
Originally Posted by Mats
When do DFI RD600 and NV 590 SLI Intel edition mobos come out for sale in Europe and which would be better for E6600??
How much will they cost?
does anyone know why would the ASUS P5ND2 SLi edition motherboard wouldnt run conroe?
Whats the difference from the P5N32 SLi edition that makes it compatible and mine not?
http://www.asus.com/products4.aspx?l...58&modelmenu=1 is a link to my motherboard.
@X-S!D3: in another month (give or take a few days), and costs would prolly be €220+ (if not €250+).
@AAmeeting: the power regulating area differs so much from netburst only boards that it had to be redesigned.
First Looks from Taiwan – RD600 "CrossFire Xpress 3200 IE"
http://www.tweaktown.com/articles/93...ion/index.html
Intel Core 2 Duo Family review
http://www.techspot.com/review/8-int...e_2_duo_family
Update:Quote:
Originally Posted by WiCKeD
Jetway has released an matx P4M9MP using the VIA P4M890 chipset
http://www.jetwaycomputer.com/spec/P4M9MP.pdf
they have also added 965G and p965P ATX boards to the us website
ASUS P5W DH Deluxe vs Gigabyte GA 965P DS3 Conroe Motherboard Shootout
http://www.maxitmag.com/maxit-review...oard-shootout/
Originally Posted by Pjoeloe
nice find i will check now :toast:
Check this out .
http://www.tweaktown.com/articles/93..._ie/index.html
this board Asus P5B isnt c2d ready? it has to be the deluxe version of it or what? but all 965 are supposed to be conroe ready? and is DFI coming out with a 975x board for c2d? whats the ETA?
http://www.inwarehouse.se/productDet...2405&ReferId=3
kaxxen..they already have...but it has a problem with going over 370 FSB...
we await the lanparty with rd600 chipset instead....
Intel DG965SSCK - µATX - Available? (prob 11th)
Intel DG965PZMKR - µATX - Not available
Intel DG965RYCK - µATX - Not available
Intel DG965WHMKR - µATX - Not available
Intel DP965LTCK - ATX - Available
Intel DQ965GFEKR - µATX -
Available?
Intel DQ963FXCK - ATX - Not available
Yes several webshops have added the intel G965 boards to there site, but it's pre order ;)
I would like to build a workstation, that has to be really, really reliable. Unfortunately, I cannot afford Woodcrest.
So I am thinking of an E6700 with 4 x 2 GB DDR-557 ECC RAM (8GB total) from MDT. I will not play games or do video editing, so a XFX 6200TC with a GeForce 6200 TC will be more than enough. The case will be a Stacker 810 with three intaking and two exhausting 120mm fans for decent cooling.
For the 8 GB of ECC RAM there only seem to be the Asus P5W Boards or the Bad Axe Intel D975XBXKLKR. I do not like the Asus Deluxe, because I do not want WLAN. But the Premium or the WS would be fine.
Do you know any other boards, which can take 4 x 2 GB ECC?
Can anybody already give some estimates, which one could be the most reliable board? I do not want to oc, but it has to be stable and reliable.
Asus advertises their superior thermal design. Is the chipset really cooler than on the bad axe? If true, the P5W might last longer?
There was a thread about dying Bad Axes and it was suggested that there might be a problem with the combination with a Thermaltake Big Typhoon (pins a getting contact with the backplane).
If I do not want to overclock, is it safer to use the Intel stock fan, or to use a TBT, which would cool better, but the boards may not be designed with the TBT in mind?
I know found these pics of P5W64 WS just thought I would share them:woot:
http://i21.photobucket.com/albums/b2...o/DSCN0001.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0002.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0003.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0004.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0005.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0006.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0007.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0008.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0009.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0010.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0011.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0013.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0014.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0015.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0016.jpg
http://i21.photobucket.com/albums/b2...o/DSCN0018.jpg
Originally Posted by [G.N.U.]Fragman
thanks for the heads-up
i cant decide wich mobo to get Gigabyte seems to oc very good indeed...
oh man i hate choosing :D
asus p5w dh seems to oc well to but gigabyte seems to hit the jackpot so far
dunno about intels badaxe... and the msi seems to oc decent
i might go for the gigabyte p965-dq6 mobo or maybe a 975 :confused: :hitself:
any piece of last advise befoer i order?
