Son of a bisket... Core 2 failed yet again at 17 minutes... really hate to dump more vcore into this thing for only a darned 3.8, wouldnt mind if it was for 4.0... whats the maximum safe vcore for 24/7 usage?
I think you should use both Linpack and Prime/Orthos.
I've had one or the other stable and the other one fail quite a few times.
Also, I tend to agree with utnorris about the VTT. One person kills a chip and puts forth a theory, which gets turned into a fact through rumours.
It's one chip. Who knows what killed it. It's an interesting theory, but not a proven one.
Once I get my WC back up and running on my RE, I'll be pushing my E8600 as high and as hard as it can go, so I guess we'll have another test on that. As Ivan Drago says...if he dies, he dies :D
Termination Voltage upped to 1.35 and now Im Prime95 stable for an hour so I have a couple questions:
1: Whats would you guys consider max for Term Volts?
2: Does raising this value in any way make it possible to lower the vcore?
*bashes head* ARGH! I forgot how much 308 hates my RAM!!!
Stupid thing is being a picky git about posting @ 450FSB. It posts, it boots, it BSOD and then DET RAM. Similar for 440. Anyone got some QX settings? Tried tweaking mine again and again but no joy. Had a bash for Grnfingers but my mobo doesn't like them 1 bit - Posts, attempts to boot and black screen of nothingness!
~Bex
maximus formula@rampage bios
modded thermalright ifx sli NB and ifx SB
http://www.pic-upload.de/thumb/01.10.08/kb6sy6.jpg
http://valid.x86-secret.com/show_oc.php?id=424850
Whats the best RF BIOS now a days?
Question... I have found my perfect settings for 3.8GHz (Prime95 stable 12+ hrs & 20 passes Linpack), been tinkering with 4.0 - 4.2 and cannot get it stable and was wondering, if I am leaving my FSB speed the same and only changing the multi from 9.5x to 10x would I also need to be upping my FSB volts or should I only be needing to up the vcore?
GJ Grn - 100mhz more and you'd be on par with my E8600! :D
My Quad's well.. I dunno.... I can do 425, and 400, and I can do 445, but it goes funny.... It sometimes goes black and then on a next power up says DET RAM. :down:
I still need to pick some new RAM.... really, REALLY need 4GB now. RAM usage was 89% today :shock:
~Bex
I need a faster kit myself, think my GSkills are maxed
http://i237.photobucket.com/albums/f...r/MII_4GHZ.jpg
http://i237.photobucket.com/albums/f.../40_gskill.png
http://i237.photobucket.com/albums/f...finger/20k.jpg
It's not the speeds that are the problem, it's the ammount. My rams done 1400mhz before! (I nearly died from shock as I spotted it after I booted - forgot to change the ram settings). I did spy some 4GB packs of Geil 1200 but it's pretty damn pricey... Don't think I can afford it unless I hold off until xmas or something :(
~Bex
What about the OCZ FLex XLC OCZ2FXT11504GK? They're rated for 1150Mhz at 2.1V, I dunno but it seems that these should hit 1200Mhz as well and only sell for 159EUR here in Holland. (http://www.alternate.nl/html/shop/pr...?artno=ICIELX&)
Just a thought....
Nah, they're aluminum heatsinks on them as well. Apart from anything OCZ RAM doesn't usually like Asus boards...
~Bex
I just bought the G.Skill F2-PC8500CL5D-PI 2x2GB kit and I'm hitting 1150MHz so far on 2.1v with a lowly Asus P5K-E on bios 1102 @ 5-5-5-15. Amazing ram! Absolutely amazing for the price (£90 @ Memoryc.co.uk).
Literally just 5-5-5-15 2T then all other timings on Auto ( I found Auto best for the rest because the bios lacks the fine tuning to match the EPP Profile manually) @ 2.1v. Performance level is 6 on the P5K with 333 Strap, 5:8 I think it works out to be? vPLL and vFSB are both @ lowest, 1.5v and 1.2v respectively (my board doesn't suffer from the overvolting when on the lowest setting in the bios).
I'll be pushing them more when I get my new Rampage Formula next week! :D
EDIT: I just saw from your pic that you're not running the "PI" series ram, maybe that's the difference?
Which board is this, Grn?
