Thanks mate. I really appriciate your comment. :)
With an MSI MB it should work. But Its possible that I don't innstall two cards before I get a bigger case. :)
I don't need SLI the first years so... :)
Here is my rig finally put together neat as I can :p:
High resolution pictures, but imageshack should resize for your screen :cool:
http://img159.imageshack.us/img159/6...8435dc5.th.jpghttp://img263.imageshack.us/img263/6...9163hv5.th.jpg
http://img263.imageshack.us/img263/6...9216wj9.th.jpghttp://img263.imageshack.us/img263/2...1471yn4.th.jpghttp://img263.imageshack.us/img263/1...2789pp4.th.jpg
Comments welcome, this is my first water cooled build, and I think I did OK. I am using a MiniNG on the 18W ultra pump, dialing the voltage down a small amount takes the edge off the low bass humm it produces :)
500x8 E8500, Abit X38, 2x1GB OCZ Titanium and so on.....
Cheers! :D
Looks nice ^^
Im sure you could neaten up those cables some more tho
Hehe, I am no neat freak thats for sure :)
Actually it was worse before, you should have seen it! Now at least the cables go behind the motherboard backplate and are out of the way for the most part. The main thing is that airflow is good, function over form for me!
What else could I do to improve it? The door opens at the front, so the tubing and fan cables to the rad need to be long enough to open and close without issue.
Plus I have a FireDTV DVB-C card, which trails the firewire and aerial cable across the case. It's not that bad is it?!:p: :D
http://i120.photobucket.com/albums/o...8022008555.jpg
http://i120.photobucket.com/albums/o...8022008553.jpg
http://i120.photobucket.com/albums/o...8022008554.jpg
http://i120.photobucket.com/albums/o...8022008558.jpg
http://i120.photobucket.com/albums/o...8022008561.jpg
http://i120.photobucket.com/albums/o...8022008567.jpg
My workstation rig... some old tech in here here... but nonetheless, it serves it purpose well.. :D
Specs:
Xeon 3040 1.83 @ 2.8ghz stock vcore
2gb 667 kingston valueram at 800mhz
Geforce 6600
Gigabyte p965 DQ6
verudium powerlite 430w
250 gb hdd - more to be added
Optical drive to be added... lol..
Wc system: TT bigwater 735, + mp-1 aqua extreme gpu block, TT Aquabay with flowmeter, TT water temperature probe, PC ICE UV red (not a big fan of tt stuff but hey, this set was going real cheap... :p: )
Nashaz: I think your rig looks sweet. Like the colour of your water.
Regarding my build. Should i try to put the two radiators in one loop then? But then i would need a stronger pump, an MCP-655 should do it. But i'm worried about the space. It's fairly larger then the MCP-355 with Petras top. :)
What do you think? :)
thanks m8.. :)
as for your rig, i feel that mounting that many rads in a mid tower is abit too tight... just wondering, have u considered the pcA71b?... or are u more into a silent solution?...
It is still doable in my opinion, that that it will be really tough to get it up and maintain it...
but i think the mosfet blocks and the nb/sb blocks are not necessary... reduces tubing clutter and u can keep the current config and placement...
sweet white rig!... :D got more pics of the inside?...
lmao... i know, i saw you sig long before i registered... lol... thats y its my workstation (aka backup rig).. my main rig is still unfinished... wasn going to post it up till it was done... but heres a little sneak peak... :)
http://i120.photobucket.com/albums/o...9012008458.jpg
http://i120.photobucket.com/albums/o...9012008459.jpg
cpu- cooltrek 360, laing d5, dtek with nozzle, alphacool bay res, 1/2" ID tygon, pc ice blood red...
gpu's - 2x mcw60, mcp 655-b, black ice gt 240, mc-res, tygon 1/2" ID, pcice yellow...
:D
It is obvious a lot of effort has gone into that. It's a neat rig to. Nice work, need to darken background or take photos without flash to see the most out of the liquid, or are you getting UV's?
Nice work
That Coolant color makes me sick, J/K. :D
Nice setup there. What case is that ??
Thank you bro... :)
ive gotten some red and yellow leds, just that i havent fixed them in... was fixing up my workstation so that i could take my gaming rig offline... also, got abit more cable management to be done as well as install a couple more things... :D
lol... Lian li PCA71B... i was expecting the red to be redder and the yellow to be more yellow... am thinking of changing to fluid XP ultra for the red.. their blood red is sick... but i heard that it makes your loop waxy and such so am still reconsidering..
Hi Guys...
http://www.coolenjoy.net/bbs/data/system/IMG_4136.jpg
http://www.coolenjoy.net/bbs/data/system/IMG_4461.jpg
http://www.coolenjoy.net/bbs/data/system/IMG_4474.jpg
http://www.coolenjoy.net/bbs/data/system/IMG_4444.jpg
http://www.coolenjoy.net/bbs/data/sy...2/IMG_4457.jpg
SYSTEM SPEC.
- CPU : INTEL Core 2 Extreme QX9650 3.0G@4.8G
- M/B : ASUS MAXIMUS FORMULA S/E
- RAM : OCZ HPC PC2-9200 2G
- VGA : ATI RADEON HD2900XT CF
- HDD : WD Raptor 74G X 2 RAID, WD 500G , SEAGATE 500G X 2 etc.
- ODD : PIONEER DVR-A212B etc.
- POWER : PC POWER & COOLING TURBO-COOL 1KW-SR
& Thermaltake Toughpowr 1200W
- CASE : Lian-Li PC-343B
- COOLER : Swiftech Apogee GTX Extreme... etc.
- MONITOR : DELL 3007WFP
- SPEAKER : Logitech Z-5500 Digital THX
- KEYBOARD : ATESSA Crystal PRO-X AKB-109U
- MOUSE : Logitech MX Revolution
GO! GO! MY NEW SYSTEM GALLERY
http://www.xtremesystems.org/forums/...d.php?t=176358:welcome:
Nashaz nice pic's :D my A71a will be watercooled soon
http://img143.imageshack.us/img143/8136/pcallnq6.jpg
http://img444.imageshack.us/img444/9...seuphddib7.jpg
Before & After Thermochill G 3/8 x 1/2: $17 :ROTF:
http://img238.imageshack.us/img238/7677/barbshs6.jpg
-Three 120x38MM Denkis at 100% 24/7 Pushing Up out of Top Grill.
-Hydrx Water Additive
-EK Block install went smooth as a whistle.
-Fan Covers, EK Block, Clear Wire Ties, Hydrx and HDD Bay Scythe Slipstream Fan all from Petra's Tech Shop.:up:
Were can I get 90 degrees fittings for the Swiftech MCR-320 QP radiator? I figured out that I may need some of those. :)
just a small preview.... making an article for print
http://img223.imageshack.us/img223/8208/dsc00528va8.jpg
jeikim ur computer, jesus, it might roll off that little table
