so nice! how did you paint :p: was it spray or yea..
gah! that's no help whatsoever!!
:hm: :poke:
Looks like spray paint to me. Look at the 5.25 bays, you can see where some of the screws rubbed the paint off.
cool.
yea I'm thinking of just painting the visible area of the case.
maybe I'll wait until the weather gets better else I'll suffocate spraying in my room ><
UV read?
From Petras? :)
Nice build btw. :)
looks great bundy!
can you take some pics of that aquaero and what functions it has?
I´m using Food color + Innovatek Protect
More about the aquaero:
http://www.aqua-computer.de/download...071105engl.pdf
http://www.aqua-computer.de/e_content/e_aquaero.htm
You've been showing your tubes with red coolant and plexi covered video card for quite some time Bundy. Any full view shots? Any new additions to your system? I'm sure we'd all like to see some changes.
Not a hater, just asking.
ooh - that looks like a shiny new PC-343B :D
Do you have any more pics?
What do you think of this? Dual loop internally mounted in a Lian Li V1100B. :)
Do you think it is going to be a tight fit? :( (Of course tight, but to tight?)
where is the bottom pump going to go? sitting on top of the fan? huh?
Yes. On the top of the fan. Fan grill you see... :)
Do you think it can work?
And this was just to illustrate my thoughts. I must try to clean up the two loops of course. :)
the case is just too small for what your trying to do.. trust me
im a previous owner.. either do 1 loop or get the full tower
Okay. :(
But I'm shure the radiator's will fit, but thats not the biggest problem? Is it?
I can't see the problem, but that's probably just because I am so excited about it. :p:
you might also have a problem fitting the front fan and the rad in the bottom.
Keeping the stock support brace where it was in my 1200, there was about a few millimeters on each side, so basically no room left. If you look back at my case, you'll see what I'm talking about. Also, you have to take into account how long your PSU is going to be.
hi there! i was thinking about your set up and tried grabbing a pic of the lian li v11000 case and realised you might not have space for 2 video cards as the top card will be right next to the rad. could be wrong, but am looking at my tj07 and i think it would struggle!
