Originally Posted by
les_paulde
Thanks grnfinger, I'm trying this as we speak. I had the skew only at 250 so that might definitely make a difference. When you say 2.1 volts, does this include the correction for the Rampage's overvolting or should I reach 2.1v when checking under Everest?
What about settings like DRAM static read control, AI clock twister and the transaction booster (PL)? Right now i have them on disable, lighter and set to 11, but am not sure if this is the right way forward?
thanks again for your help! :)
EDIT: system still keeps crashing, also using bios versions 0308, 0401 and 0408. Even using the official P5E Deluxe bios 0501 and 0502 does not result in a stable system, although the memory is clearly listed on Asus' QVL for this board... I've tried voltages ranging from 2.08v to 2.22v in the bios, and I also tried tRFC at 60 but unfortunately all to no avail.
Does anybody have any ideas what else I could try?
