n0vaaa pvc 8\11 tubing +mopar 7170(half with disteled whater)
case will be on the wall) now only mounting some things
Old chieftec maybe?
Yep, an old chieftech dragon. The new revisions have a 120mm fan at the back.
that thing is hugE!
http://shrani.si/t/2U/s9/8slLTIZ/dsc06020.jpg
my h2o system:)
Searching for some watercoolers that will fit on the DFI. :)
http://www.abload.de/img/imgp32225rz.jpg
http://www.abload.de/img/imgp3223avo.jpg
http://www.abload.de/img/imgp3224yyp.jpg
http://www.abload.de/img/imgp3225ifh.jpg
I know that the CPU block is not mounted as it should but it doesn't matter. When you look at the copper plate desing you will see that only the intake matters and not the out take.
The only reason for mounting it like it should be is to get the air out easier. Getting the setup air free is not a problem. The reason i have it like this is for getting to the NB blok easier. If the out take of the CPU block would be as it should be getting to the NB block would be very difficult.
The aluminum in the res is also not a problem because i run with 50% cooling liquid for a car that protects againts corrosion. This PC is running for over 18 months without any problems. The copper of the old waterblock still looks perfect and so does the aluminum of the reservoir.
Go to a store where they sell car cooling liquid. That stuff comes in just about all the colors that you might want for watercooling. You can still add destilled water with it.
I run on 50% car cooling liquid wich is quite pink, the rest is water. I bought the stuff here in holland but i'm sure they sell it in russia too somewhere. Then just use clear tubing like Tygon or PVC.
I already founded the Feser One Fluid UV Pink, but i want to found UV pink tubing to combine them and there is problems with finding tubing not liuqid. But if i will not find tubing i want to use Tygon (transparent) with Feser One.
cka3o4nuk nice to c u there and it's cool to see your project almost finished.
You are in the perfect place to get these "watercoolers" from MIPS Computer. I wish I lived in Germany just so I could have better access to MIPS waterblocks. If you get these blocks please let us know what you think.
those mips are crap arnt they? i asked in the dfi x38 thread and im sure i was told that
I got a full MIPS set for my P5W DH. They are not cheap but they are quite good in my opinion. Build quality is very nice and they give good temps.
I do think that they are to expencive for the amount of material used.
Here in Holland i can get them pretty fast, about 1 tot 2 weeks.
Hello again water-cooling world :)
http://www.abload.de/img/343-mdpc-01f8x.jpg
More pictures at www.million-dollar-pc.com!
Silly domain-name :p:
Would be great if we could collect a lot of beautiful liquid-cooled systems / rigs on million-dollar-pc. The great rigs shouldn't get lost. We have so many threads to go through in XS - we don't wanna miss a thing! If you have great stuff, please support :)
Very nice :)
Rbs.
:wave:
Looks great!
I need to move the upper t-line close to the pump and get the tubing a bit cleaner.
