wow that will be awesome my friend :up:
i see you just switched it around for your username:D
man im not having any luck whatsoever with my UD7 and i3-530:mad:
it has a nice low vid of 1.13v but i can even get 20x200@4000 1600 cl9 to boot:down:
dont know if its the board or the cpu,i need to get another H55M-UD2H to find out.
thank god my E8500 will be here soon,i know i will have better luck with it:up::up:
No time to bench but tossed the E8500 in and booted at 4.56 on second try, should be fun when I get time.
VID is 1.1
I just picked up a QX6850 that is lapped in a trade, so i will be slammin that into the GIG UD3P tomorrow, should be fun to see what it can do...
Uruguay claimed their first World Cup semi-final appearance in 40 years after a pulsating 4-2 penalty shootout win over heartbroken Ghana
andre I still can figure out how to "take a pic" of the bios like you guys have and posted it. I know once you get a screen shoot you can upload it to imageshack and post it . Anyway I changed my settings to mirror Jsquire and it booted fine up to 425FSB. I tried 450 and it wouldn't get past the windows load screen I'm thinking this chip needs more than 1.4Vcore? What do think?
if you mean the bios template scrollbox then this will help you.
just copy and paste and heres how to put it into a scroll box.
first at the bottom of the page where the reply box is,hit the go advance button.
then when your in the advance reply page,up on top of the reply box you can see
the button that looks like this #,click it and you will now see in the reply box this appear.
[code][code]
paste your template between the two [code] boxes and the template will now be inside
a scroll box when you post it.
but if you mean actual pics of you bios screen then you need to upload the pics like you did
and then post the link address to the piscs.
First I get how to post the bios once it's in my pics folder. And I also get how to upload it and post on the thread what I don't get is how to "copy" or "take a pic" and move it into a folder so I can do those things. It might be the most simple step but I just can't get that part. Never done a screen shot of the bios before. But anyway I had to increase Vcore up to 1.5V in the bios to make it stable at 450Mhz and that was to much, I couldn't keep the temps down. It runs 75-76C at 100% load so I guess I'm looking for a new processor now:down: I was hoping to get at least 500Mhz and the chip might do it but not on air.... I'm gonna look for a E8600. Thanks guys
Whats the Vcore droop on these boards anyone measure it yet? And if it's like what the other gigabyte boards are is there a mod? Also what program do you use to measure Vdroop?
you can just take a pic of your bios settings mate and up it here
http://imageshack.us/
or just use one of the templates posted and edit it and re post
no need to mod anything mate just enable LLC
cheers :toast:
Sergio
Been a while since I've updated in this whole thread I gotta catch up; been busy with things lately. I'll try to get on MSN sometime Sergio :) and go Uruguay! :D
To update my board doesn't seem to like frequency latch of 400 and I figured this out after some games were crashing. I ran prime custom 8k and it passed, however blend failed after a few seconds and I even got a BSOD a few times :eek:. It wasn't responding to any bios settings so I changed it to 333 latch and it seems to be fine and stable, it passed both blend and custom 8k now, and no more crashing or nasty BSOD ;) Although, my ram latency shot up 20ns and read times went down, I think this is typical but will it really affect performance in games?
I raised vcore up a tiny bit after Sergio helped me as I was getting BSODs again and I thought I fixed it by doing this; but I guess murphy's law is right. I am running LLC at 1.43125 in bios and I'm pretty sure this is borderline safe for 24/7 as I've been running this for a few weeks but didn't notice instability cause I was just browsing the web for most of that time. I'll try lowering it tommorow and I'm pretty sure it will be fine. Temps are too high for my liking in Prime 8k, it hits 70C and I want to stay under 65C, and this was after reseating with IC7 compound and attaching 2 Gentle Typhoons to the rad in push/pull. Couldn't imagine what temps would have been before :eek:
Finally got my camera back Sergio, this was the new loop I built, currently taking things apart to switch mobo's so its even more of a mess than normal. The bottom cap to the new res has a leak to I turned it upside, works fine now though.
http://img535.imageshack.us/img535/7412/re3.png
Uploaded with ImageShack.us
I like the sideways mounted RAD.
Thanks, it lines up perfect with the vents on my window ac.
Thanks Sergio, the cables are a pita but I am use to it.
Hi all,
Just to let you know that I'm selling all my P45 boards (UD3P, USB3P and MIIF), GSkill PI 9600's and 1296MHz+ capable OCZ reapers.
Details in this thread - further details on my Ebay account
Hopefully any of these in the right hands are bound to go far - all the best :D
