Tw1st3d what pump is it? And why u use 2 three-way adapter?
Figured i would post a couple of pics of the new rig. i havent finished cleaning up the wiring yet nor have i finished with the lighting but i figured yall might want to take a look
done benching for now cause i want to play some games but finished up at qx9650@4455mhz(405*11), maximus formula, 8800gts(g92) (850/2067/2200)-vgpu 1.35v -- WinXP
'06 -- 18560
EK Supreme on QX9650
EK fullcover on 8800gts (g92)
EK NB block
EK Asus 3a 2 x mosfet blocks
loop 1 --> cpu & nb -- 120.3 rad
loop 2 --> vc and both mosfets -- swifty MCR220 rad
Dual bay res with 4 barbs so both loops in 1 res
http://ubc_ccc.home.comcast.net/H20 ...ture 004-1.JPG
http://ubc_ccc.home.comcast.net/H20 ...ture 005-1.JPG
http://ubc_ccc.home.comcast.net/H20 ...ture 006-1.JPG
Very very nice CCC!!
The loops are well routed :up:
As i scrolled over those pics CCC, my speakers went, "Bling bling bling"
dangerden TDX
BIXII x 2 medium uv yates
masterkleer 7/16" tubing
T-line
dangerden pump
dangerden typee x1950 water block
fluid xp.
im new to this forum =].
My watercooling
The rad and the fishtank, you can also see steve the inflateable pumpkin
http://i91.photobucket.com/albums/k3...y/DSC_0631.jpg
http://i91.photobucket.com/albums/k3...y/DSC_0630.jpg
http://i91.photobucket.com/albums/k3...y/DSC_0629.jpg
http://i91.photobucket.com/albums/k3...y/DSC_0628.jpg
http://i91.photobucket.com/albums/k3...y/DSC_0626.jpg
The pump sitting on a sheet of folded bubble wrap
http://i91.photobucket.com/albums/k3...y/DSC_0623.jpg
http://i91.photobucket.com/albums/k3...y/DSC_0620.jpg
that's my ex MBO, p4c800:) had a mobile pent on it, watercooled...
what's the rest of the config?
Mindless, your rig is completely ghetto. :up:
http://xs123.xs.to/xs123/08052/img_2658208.jpg
XFX 8400GS on D-tek Fuzion GFX, hitting 1ghz on the core, 2540mhz shaderclock.
Hello.
After a while I made same changes to my rig.
This is link to previous version: http://www.xtremesystems.org/forums/...07#post2245407
I added second graphic card NV 7950GT in SLI mode with Alphacool waterblock, then additional 2Gb of RAM with second RAM waterblock.
Now I have 10 blocks (7 homemade, 2 Alphacool GPUs, 1 Innovatek HDD) with 2 2x120 Radiators, 2 Laing waterpumps.
I also upgraded CPU to Athlon AM 6400 x2 (125Watt of heat to dissipate - previous produced only 65Watt)
Temperature : GPU 36* to 38* stress, Processor 40 to 48* during stress, NB 30*, Water 25*C. Wents are running at 2/3 of nominal speed . With two pumps running flowmeter showes 780 RPM on single punp just 520RPM.
Pictures now:
Before upgrade
http://i29.photobucket.com/albums/c2...emachinery.jpg
http://i29.photobucket.com/albums/c2...oardblocks.jpg
And after upgrade, to fill the space I added old Voltometer and Amperemeter and some light with UV cathodes
http://i29.photobucket.com/albums/c2...ki/kmpnew4.jpg
http://i29.photobucket.com/albums/c2...ki/kmpnew3.jpg
http://i29.photobucket.com/albums/c2...ki/kmpnew1.jpg
Top of my case stays the same as previously.
http://i29.photobucket.com/albums/c2...ki/kmpnew2.jpg
Greets
it's what it looks like, a p4 prescott 3.2, the board no longer likes to be overclocked, used to run it at 4ghz. an x800xt clocked at something silly, and some old school original BH5 ram.
The watercooling was basically an experiement, i'm buying a new computer soon and want to go straight to water, so i thought i'd try it out, funnily enough the whole setup was less than£100, so just under $200
http://img262.imageshack.us/img262/9045/dsc00003xl1.jpg
Re did machine :)
Why? Improve loop flow and get more air to flow through the radiator.
My new water system that i upgraded in december from a total ghetto one. Pics are form last month and its abit tidier now actually.(got rid of the yellow ide cable)
http://i170.photobucket.com/albums/u..._122_999lo.jpg
http://i170.photobucket.com/albums/u...122_1005lo.jpg
http://i170.photobucket.com/albums/u..._122_388lo.jpg
http://i170.photobucket.com/albums/u..._122_412lo.jpg
http://i170.photobucket.com/albums/u...122_1028lo.jpg
Links to the images don't seem to be working
Changed hosting
same I was like I want MIPS blocks for my mobo so bad, like his. then I read the description and was like really??
That blocks are homemade by Misiu15go ;) [half price Mips blocks :D ]Quote:
I love those blocks, almost thought the were from MIPS. Very nice!
Rebuild / Loop Rehaul finally finished. :)
http://farm3.static.flickr.com/2074/...eccf842d_b.jpg
http://farm3.static.flickr.com/2059/...de129a75_b.jpg
White light looks pretty awsome. ;)
I am going to be using that my self to. :)
Nice build btw. :)
Nice build. :up: It looks very clean. Those white/blue ccfls look sweet. But how bad was filling and bleeding with the res like that?
Thanks.
I had to top up the res a few times and bam, it was filled.
And as for bleeding, I ran the loop by itself by powering it with another computer.
So I was able to move the rad and cpu block around to bleed it. I left the cap of the res off and I'm pretty sure it took less than 5mins to bleed it.
