299RMB/7.5 = $40US or so
Doing a refresh on my ancient V1200. I love this case! This is only partially done, I'm still waiting on a side panel, good rubber fan mounts, and a donor V1100 for internal parts and the USB/Audio front panel module. I will be stripping them from the case, making necessary cable management parts, then getting them painted black at the body shop next door.
http://img695.imageshack.us/img695/3603/sam0096v.th.jpg http://img836.imageshack.us/img836/4317/sam0099p.th.jpg http://img684.imageshack.us/img684/3516/sam0103s.th.jpg http://img683.imageshack.us/img683/3685/sam0109c.th.jpg http://img714.imageshack.us/img714/7176/sam0111k.th.jpg http://img833.imageshack.us/img833/6189/sam0112u.th.jpg
Mine.
http://img.photobucket.com/albums/v4...5/DSC_2058.jpg
Never bother to do cable management. Haha.
Should be a Noctua C12P.
Yap. Its a noctua C12P with a scythe sflexE.
Why there is that little heatsink on top of the base? O__o
My computer is not the best, but it makes me happy <3
http://img222.imageshack.us/img222/6976/dsc05071ps.jpg
http://img263.imageshack.us/img263/8718/dsc05075ps.jpg
http://img607.imageshack.us/img607/1057/fotoa0023.jpg
http://img716.imageshack.us/img716/4281/fotoa0028.jpg
I just want to exchange the computer but keep the video card.
XFX Love <3
Lapped my TRUE Cu and my i7 920 (I had a free afternoon) :D
Load temps @ 4.2GHz have dropped by at least a further 5C :up:
http://img264.imageshack.us/img264/2182/lapped2.jpg
http://img8.imageshack.us/img8/5094/lapped3.jpg
igortricolor, what are you using as a camera??
Just squeezed a Silver Arrow inside that pooer-little SilverStone Fortress FT01, ATX case, on top of the SR-2 :)
Tried a Noctua NH-14 on CPU#o, but couldn't get a better temp.
I guess those huge coolers where choking each other, or something, so I ended up with a Megahalem on CPU#0 for now.
Both CPUs are running with the same load-temp. :)
http://img.techpowerup.org/101116/Capture066.jpg
http://img.techpowerup.org/101116/Capture067.jpg
http://img.techpowerup.org/101116/Capture070.jpg
Oh my God Sam, you need to get a more open case! I don't think Fortresses are made to have that much ventilation demand!
My first attemp of bench table. Same desing of Banchetto 101, but DIY :P
http://i231.photobucket.com/albums/e...o/IMG_2570.jpg
http://i231.photobucket.com/albums/e...o/IMG_2576.jpg
http://i231.photobucket.com/albums/e...o/IMG_2575.jpg
http://i231.photobucket.com/albums/e...o/IMG_2573.jpg
http://i231.photobucket.com/albums/e...o/IMG_2583.jpg
http://i231.photobucket.com/albums/e...o/IMG_2584.jpg
http://i231.photobucket.com/albums/e...o/IMG_2585.jpg
I need to improve the edge to make it transparent. After that, build all the table.
regards from chile
