That's rather bizarre because I've been running my G.Skill @ 1088 with only 2.0v. In fact, it can run as fast as 1105 with just 2.0v, and the only aux cooling I have is the side 120mm fan adapted from my LL G70 case to my A77. If I place a fan on the memory it will go as high as 1115 with the same 2.0v. Adding more voltage only seems to produce more memtest86 errors. For testing I initially run memtest 5 for 10 passes then if it passes, I run the entire test overnight. I also run OCCT for an hour, Prime small fft for an hour, then Prime blend at least 12 hours. The memory has never failed once.
I built a system for my brother and he has the exact same G.Skill memory which behaves very similar to mine. He has an E8600 running @4400 with the ram at 1115, 2.0v.
Here's my system:
http://i61.photobucket.com/albums/h5...95smallFFT.jpg
