My new Alphacool 120mm rad in the WCS:D
http://img111.imageshack.us/img111/883/97075985lt4.jpg
Very nice
Did you notice any difference in temps? I'm thinking to add one MCR120 here too :)
Rbs.
:wave:
My vga drops 5 degrees:D
its look soo nice, something notice change in temps, and the copper mofsets heatsinks cooling well? , i think add this heatsinks but i look too the thermalright mofsets heatsinks, but its a little huge
please post some more m8. that looks awesome
Guess I should throw mine here as well :D Cloudy tubes are lovely aren't they?
http://i266.photobucket.com/albums/i...3/DSC00625.jpg
A little more clear shot of the inside:
http://i266.photobucket.com/albums/i...3/DSC00624.jpg
Shots with flash:
http://i266.photobucket.com/albums/i...3/DSC00622.jpg
http://i266.photobucket.com/albums/i...3/DSC00621.jpg
And finally, my masterpiece, the 8 ziptie gpu block mount:
http://i266.photobucket.com/albums/i...3/DSC00623.jpg
I never bothered to take pictures of my blocks, sorry to disappoint ya all. They're really ugly on the outside and the inside anyways :P
I also am aware that the tubes have green stuff on them. This is not algae. This is what happened after the minerals from the tap water I used the first time collected on the tubes, then the zinc on the screws that I didn't mean to have touching the water corroded and turned everything pink, then I cleaned it with lysol toilet bowl cleaner which is BLUE so it turned green :D
Heres mine,
My first build so please positive criticism. Thanks
http://img403.imageshack.us/img403/8278/img1343sc0.jpg
http://img149.imageshack.us/img149/7731/img1339ru4.jpg
http://img152.imageshack.us/img152/2793/img1346pl0.jpg
http://img180.imageshack.us/img180/2679/img1347wm0.jpg
damn glos thats a hell of a setup i especially like the g15 and deathadder combo i have the same
Very nice build Gios :up:
I'm in the process of installing water cooling in my TJ07 and am always looking for new ideas for this case.
Could you post more pics showing the radiator and pump locations and the hdds?
Hey thanks guys!!
It means alot since its my first build.
Yeh I'll have some for you tomorrow its late I gotta go work tomorrow haha :D
Its a tight fit, but if you route the tubing well and cables, you can fit the rad, pump and HDD cage in the bottom compartment.
I found the possible airflow restriction to not have any effect on my temperatures.
I'll put em up soon :D
tj07 ideas look no further check out my blue devil build which i will have updates for soon
hahaha i love you wallpaper :D
Me wants now :D
Rbs.
:wave:
nice loop and cable management.
did you cut the base of the case?
i thought Laing D5s weren't meant to my mounted up side down? or am i thinking of DDC.
it's fine as long as the pump inlet is not pointing up.. even that I think doesn't matter much if you take proper care when bleeding (so the pump never runs dry while filling, etc)
nice work gios take some days shots :)
I recived my Red UV dye in the mail today :D
Here is a pic of the Dye added :p:
http://img99.imageshack.us/img99/2167/dscf0004yq8.jpg
AAaa, looks like pink:D
Very nice LED effect!
wow thats sick bundy...
is the led in the top or just pointed @ it?
there are 2 LEDs inserted into the top. Easiest to see in the first pic
