The new standard of silence is comming in all SS units. :)
New condensor + 180mm 12V fan with 22dB noise level.
http://ld-phasechange.com/images/Lit...C_Cases/27.JPG
Kind Regards
Kind Regards
Which fan are u using? Silverstone's?
Great choice! They are powerful and almost inaudible... :up:
Aften 2 hours on load. :)
http://ld-phasechange.com/images/Lit...seChange/2.JPG
http://ld-phasechange.com/images/Lit...seChange/1.JPG
Kind Regards
Very nice result! :clap: :up:
Is that done with a Danfoss NL11F compressor?
And is that new condensor one from LUVE?
Yes Danfoss NL11F and old condensor. Waiting for new fans, than we will see new results. :)
Power consuption @ 300W heatload:
http://ld-phasechange.com/images/Lit...Complete/9.JPG
Power consuption @ 260W heatload:
http://ld-phasechange.com/images/Lit...seChange/4.JPG
Power consuption @ 215W heatload:
http://ld-phasechange.com/images/Lit...seChange/3.JPG
Kind Regards
Yes condensor is from LU-VE.
300W heatload. :)
http://ld-phasechange.com/images/Lit...k%20rev2/9.JPG
Kind Regards
I finally finished my build! (for now)
Placed a phase-change unit in a LianLi V2010B.
http://users.telenet.be/UTerror/phase/pic1.jpg
http://users.telenet.be/UTerror/phase/pic2.jpg
http://users.telenet.be/UTerror/phase/pic3.jpg
I've got 1 of the old type of units with the 220V fan which makes lots of noise :(
So I changed the fans into 2x scythe slip stream 140 mm (push/pull).
Temps are a little bit better then original fan (+-5 °c without a load).
Suction line was a bit too long, but fixed that by routing it in bottom half of the case.
Tested it this week and it's working great, but I need to order some parts like power buttons, wc block for motherboard (vreg gets too hot), cable holder's, ... I can start painting the case when that arrives. Should be fully finished in about 1 month.
Greetz,
UTerror.
Nice rebuild! You shout show us picture of finished unit also =)
kind Regards
NL11F is holding 283W at -30C? Nice work!
Also, isn't the COP for that unit like 85%? 283/354?
Rotary unit on load.
http://ld-phasechange.com/images/Rot...aximous/15.JPG
http://ld-phasechange.com/images/Rot...aximous/14.JPG
Best Regards
Hi LD,
Is it possible to run the compressors at a lower speed when the computer is idling to save on power?
How much for the case and cooling unit?
you can use vcc rotary compressors which are controlled by frequency.
they are often used on inverter coolers
But you'd need more room vertically.^^ :D
And more money for the extra parts. ^^
you can also use full hermetic piston compressors: http://www.embraco.com/ingles/familia_vcc.htm
Would it be effective enough for 24/7 operation, though? Sounds nice indeed, but I wonder why noone considered that before... :D
expensive and difficult for an automatic control.
you can use a frequency inverter and select the frequency manuelly :D
but on singlestage it doesn´t make sense such a compressor, because you have to insulate all the parts so it doesn´t matter if you have -30°C or -45°C on idle.
You should do a quick youtube video of that case running :)
