:D :D :D :DQuote:
Originally Posted by jVIDIA
(vamos embora tugas ao poder :D)
:D :D :D :DQuote:
Originally Posted by mascaras
Bora lá!
Did some tests... Nothing much. just wanted to brake the 10k barrier.
http://img89.imageshack.us/img89/668...02291km.th.jpg
Stock cooler...
Next.....
Tuga Powa!
mai nada , ainda das bem mais , eu dei 10350 com stok cooler num sinle core , ainda podes puxar bem mais pelo core, usa o powerstrip;)
New Result from Switzerland !!
http://www.bilder-hosting.de/img/CJB7M.jpg
Regards
SPLMANN
I guess its true what I've heard about this site. Unless your a very regular here you just get ignored in these forums.
what was your question, or concern?Quote:
Originally Posted by MsB
xfx 7900gt
vmod 1.4v water.
First try with a XFX XE 520/1500 @ 713/1826 under waterchiller
VGPU 1.5V, VGDDR 2.23V
Liquid @ -19°C @ full
http://img308.imageshack.us/img308/8...0gtvmod6sd.jpg
Arg, you guys are killing me. I can't even break 9K with my 7900GT @ 666/1920.
@Ebola:
Nice try, First sub-zero 7900GT here I think?
@lowfat:
Allready tried a new windows install and de newest drivers (WHQL)--> www.nvidia.com
And did you set Performance & Quality settings to performace? :p:
Here i learn that Shamino's card kick teh ass as his GT perform a nice 745 @ 1.5V but with air, either cold doesn't bring that much either its card really rocks :P :stick:Quote:
Originally Posted by UTF Nightmare
lowfat, I had the same problem with my 640@4.1.
I was and you are CPU limited !!
Changing to 920D was the solution !!
Stock voltage, stock cooling (waiting for my VF900), the rig in my sig
3DMark05 - 9206
http://img502.imageshack.us/img502/2499/05-OC.th.jpg
6,108 in 3DM06.
eVGA 7900GT with the 1.4V mod @ 655/1818. X2 4800+ @ 2.8Ghz 1:1
ok , with waterblock alphacool nexxxos NVXP-3 and with 1.4v MOD my temps are 27c idle and 30c full load :D
XFX 7900Gt XT (520/1500)@650/870|||Opty 148@2990mhz
http://img426.imageshack.us/img426/9946/overclok7oz.jpg
XFX 7900GT XT @1.4vMod Temps/Idle
http://img316.imageshack.us/img316/9...mopidle7qh.jpg
this means one thing ....................... she wants 1.5v cause she have cold :D
regards
Mine does fairly well with the stock cooler, tjeck the scores in Sig. I will be buying an VF900-Cu as soon as they get in Stock and then i will apply the coductive stuff and do the 1.4v mod.
/Grau
Good job guys, too bad I can't just zip on over to newegg and grab up my new card.:( I'm dyin to get my hands dirty with some volt mods benches.:banana: :banana: :banana: :banana:
I was thinking the same thing. All the single-core P4s are scoring poorly from what I have seen. I'll upgrade to a 920 here soon, hopefully that will help out.Quote:
XFX 7900 GTX 512 Extreme Edition 710/1800
stock cooling
x2 4400+ @ 10 * 250
3D05 11509
3D06 6312
nice:)Quote:
Originally Posted by Raphie
Does anyone have the XFX 7900GT non-extreme? Does anyone know this version also have BC14 Samsung memory, just like the Extreme?
I bought two of these for SLI and modding :D :toast:
12K done!
750 + 20 MHz / 1820
1.6V core / stock mem voltage.
Attachment 45454
Best bang for the buck :D
Edit:All on air
http://service.futuremark.com/compare?3dm05=1927387
Does anybody know if the XFX 7900GT XXX version use any other memory than the other Xtreme versions?:fact:
