let me know d00d :)Quote:
any of u tried to remove the ihs off?
or can't remove it?
SiLA, it depends of the room temperature but arround 38º C with 24º C in my office room.Quote:
Originally Posted by |SiLA|
As for the IHS from the 9xx family I think it's almost impossible to remove them, because they are soldered do the cores.
Originally Posted by jVIDIA
hmm ok ty very much
so this pentium d are really hot in full load..big jump of temp...never had those warm cpu on amd :(
like 4/5°C of difference on idle/full :(
Yes they are.
And the bad quality of the IHS doesn't help too. :(
that's why i wanted to remove it :(Quote:
but i guess all i can do is avoid the warranty just to make it looks like jsut normal copper
dunno how to call that in english :D
maybe i can fix the ihs
You are talking about lapping the IHS ! Yes that's the solution.
Try to sharp it with a file.Quote:
you can remove the IHS. just use a low heat butan torch on the top of the ihs and make sure you cut the glue first.
heat it up a little bit and pop it off.
Pop it off with core. I think that this isn`t good idea :DQuote:
Originally Posted by exhausted mule
wow all these results made me drool :slobber: :slobber:
my Asus P5W DH will arrive tomorrow. Im also getting a Pentium D 930 from frys to play with. LOL its cheaper than Pentium D 920 :D :D
BTW what kidna clock can i expect from Pentium D 930 with Bigtyphoon, and vcore to prolly 1.35V 1.4V
expect @vcore def from 4ghz to 4,2Quote:
Originally Posted by theteamaqua
change of plans i just got the 920 for $140 USD in frys. with Bigtyphoon how far should i go?? for 24/7. im doing 3.36Ghz at 240Mhz fsb 1.4 vcore now. I think this can go higher . @ 3.36Ghz the temp is around 40 to 42c idl and prolly 50c at load when i run pi 32m (didnt finish 32m cuz i had soo much stuff to install).
like 3.7 , 3.8GHz at 1.4vcore ??
EDIT: well at 3.73GHz 266fsb 1.415vcore. idle temp is around 42,43c and pi 32m is like 54c. about 52c when playing FEAR. maybe i could go higher since my room temp is 23c.
EDIT2: boy, i hope Asus AI Booster is accurate... or report higher temp.
I'm having trouble booting my 930 with more than 294mhz FSB on Asus P5WD2-E and 1:1.
I have 1.3v for FSB and 2.1v for Ram, CPU on 1.45v
Using H20 cooling for cpu and NB has swiftech fan bolted to it.
Using 601 bios.
Any suggestions ?
MCH voltage ? Try 1,55v ;)
Look at my 930D on my sig :D
I'm also on H2O.
Thanks jVIDIA, but the MCH is already on 1.55v. I think it might be the mobo.Quote:
nice 930 u have there anyway jVIDIA with 1,43vcore i can run at "only" 4600(307x15) mhz :(
310x15 i need like 1.45 314x15 1,47/1,48
when u ppl oc do u care about prime 2004, 95 or do u only care about temperature??
What the hell is that????
show more WR results?
not sure if theres a place for 920 aircool
http://img136.imageshack.us/img136/8817/17id3.jpg
http://valid.x86-secret.com/show_oc?id=105562
also i cant see the 920 aircool WR that image is removed
Alright i got a new placeholder for Conroe, Presler 950D
Previous owner said 4.54 Ghz 1.45v on air is good
I'm topping out at 4.50 Ghz with 1.47v (1.56 in bios) on watercooling
http://img.photobucket.com/albums/v7...l/c94f1813.jpg
I have to clockgen up to that speed. CPU is acting very messed up. Here are a list of symptoms:
1) SP2004 large FFTs fails at stock settings within 4-6 seconds
2) Clockgenning up, i start failing applications in the 3.7x range... 3.85 Ghz at stock volts and i get restarts.
3) Booting past 250 FSB i run into a condition where programs like prime & Sp2004 crash instantly, they don't even begin to run. Also games are messed up, CSS runs at double speed. I cannot figure it out.
4) Booting up at < 250 FSB and clockgenning up, i am unable to get stable anywhere near anticipated.
4.4 Ghz requires over 1.5 volts, 4.5 Ghz requires 1.575 volts set in the bios and some things will randomly crash (SoB in particular). Anything over 4.5 Ghz, even with plenty of volts gives me crashes and restarts. SoB, Firefox, Explorer, everything will crash and dual load will restart it.
I can provide screenshots of all these things, cept CSS.
CPU is watercooled.
Everything other than the CPU was tested on a Celeron 336 and everything else is good... ram was underclocked for everything above. Tried different ratios, no succes. Tried different BIOSes, no success.
lapped my cpu and gained around 7°C in full load
http://img111.imageshack.us/img111/3...800x600gc9.jpg
7 C? That's a good difference. May have to consider lapping.
http://img76.imageshack.us/img76/33/shot0001mn7.jpg
dual prime stable 3.8GHz air cooling with bigtyphoon. i will get tower 120 once its availible. Hoping to get 3.6Ghz on E6600. This board is pretty good. I like the timing change.
i cna boot at 3.8Ghz. Have not tried any higher. In BIOS, vmch, vfsb were +0.2v and vdimm 2.1v, vcore was like 1.55 (1.46 , 1.48 actual ) i think. during load the vcore osmetiems drop to 1.42.
http://valid.x86-secret.com/show_oc?id=106081
Probably my last update to this thread for a while with dual core Netburst chips (waiting for Kentsfield...) This thread looks like its dying out with the excitement of Conroe.
http://service.futuremark.com/compare?pcm04=3250835
http://img133.imageshack.us/img133/3...1132242yh1.jpg
ScienceMark 2.0 with 27 background processes running - good stability check with CPU and Ram for real world conditions.
http://img224.imageshack.us/img224/7...groundpcr1.jpg
