Originally Posted by ixtapalapaquetl
Well, I've been trying for over a week to get my Expert to play well with my G.Skills using my 175. Tried five different BIOS's and literally every combination of Driving Strength/Data Strength/MAL/Read Preamble. For the life of me, I couldn't find a combination that would let me run CAS 2.5 at 1T stably. My longest prime run was 59 minutes, always failing large FFT's. The system just felt unstable. I knew it was memory related but couldn't make the necessary adjustments.
So last night I said to hell with it and switched to 2T. All my problems were immediately solved! Running like a champ now. Obviously, this is not the ideal solution, but until I can figure out where I have been going wrong, 2T is where I be. All shots below at data/drive strength 7/1 (the only combination I had luck with).
So my final verdict on the Expert: it's a keeper. I have been able to match my max overclocks with both my 148 and 175 on my Ultra-D. More importantly, the Ultra-D/175 combo had dangerously inaccurate voltage reporting problems (.11v over CPUZ under load). The Expert is much more accurate - the above prime shot reads 1.591v with a DMM under load and 1.579v idle. Once I get my memory sorted out at 1T, this system will be a beast.
