Originally Posted by Clocker
I was running my CPU at default voltage (1.4v) with a 240Mhz FSB and 0.83 memory divider (so I was running ram at ~200Mhz). HTT multiplier was 4x.
WIth CnQ running, the CPU was running at 1200Mhz and 1.1v according to the AMD program. CnQ was running when I left the house and when I got back the system was dead.
Is that stressing anything other than the CPU ('cause of higher clock speed)? Does the above config stress the NF4 chipset? I was using a Zalman passive heatsink on the NF4 chipset. I'm doing that now too but I have a little 40mm fan on it just in case....
CxP
