Really good, but I think that is really more than enough for this kind of cooling :)Quote:
Originally Posted by coop
When I use TEC cooling, with colder temp than you I use only foam on mobo and on on wb and all is perfect ;)
Anyone??Quote:
Originally Posted by derektm
Go to local store hand pick one. pay a little more if you are into stepping. I believe most of us buy few and return whats not decent or sell them.Quote:
Ah ok. How much more would one be at say Compusa than newegg? As long as its not way overpriced I don't mind.Quote:
Originally Posted by jinu117
Hmm: http://www.compusa.com/products/prod...524&pfp=BROWSE
I'll have to go by CompUSA and pick one up. You think thats a good price? Wish I could get them to beat newegg's price.
Edit: Crap, no stock... CompUSA - :slapass:
venice 3200+ currently at 2780mhz 32m spi stable
LBBLE 0518EPAW
Watercooled full load temp 42-43
Huge voltage thoughQuote:
Originally Posted by QUARK
Yeah man, it's a crazy voltage, be carefull ;)Quote:
Muahahaha! I have 2.8ghz at 1.77V :DQuote:
Originally Posted by Toki
quark lower you voltage to max 1.5
i need 1.52 for 2850 !!!!
Some of us need an insane viltage to reach such speeds, many Venice CPUs suck a horses behind.
I can't find any local stores that have any Venices. We don't have Fry's here. Any suggestions? :(
I've got an Idea. Im going to start calling every online retailer and see if they will tell me the steppings they have.. if I get any that will tell me, what should I ask for? What would be the BEST and if they didnt have that what would be good. Need a list to ask for
Thanks everyone :)
Edit: Mwave.com: "No theres NO way!" - Wow that was a Bit**!!
Do NOT call these people. :stick:
3000+ EPAW and DPBW seem good
317*9 after 2h 35 minutes prime errors :)
1.275*123% bios aka 1.52 appx in cpu-z
not bad eh for Zalman 7000b-alcu :woot:
www.thegrafixguy.com Was really nice but he said they have several differnet warehouses and that its not possible... hmmm maybe all these online retailers ship from the same warehouse?
Go to the closest chinatown, forget about CompUSA-type places. If you find a place with the AMD64/ FX flag in the window , go there and find the guy with the worst hair possible, and ask him if you can hand-pick a chip.
Regardless of week, it is always a bit of a crapshoot, but if you know exactly what ones you're looking for, that might work. They probably only have ones that aren't even listed on here yet.
Well I don't believe Arkansas has chinatowns. All the places I called here still have suckass socket 754's or not any Venices, or they don't even know WTF a Venice Core A64 Is!Quote:
Originally Posted by Fission
Anyways, I found an online retailer that is helping me pick one out (hopefully). Im holding right now while they check all their stores stocks.
if i lower my voltage it won't get in to windows. and its stable for now. i will try to go higher in a couple of days when i got the time for it. btw whats the highest vcore anyone have tryiet?
http://slike.slo-tech.com/14148.jpg
LBBLE 0516 GPDW :woot:
Nice, cooling?
This was on my LP previous to now.Quote:
Yo crazy man :DQuote:
Originally Posted by Juliette
What's the point?Quote:
Really cold water, but I guess not more than a 226W TEC setup on the mobo/cpu.
Point was, your cold is isolated under the heatsink in a small area. I had/have to bring mine from a much further distance and condensation presents more of a problem if not insulated properly. Thus the more extensive insulating technique, even though it may not be as cold as yours.
My system specs in sig.
This is 32meg pi stable / prime95 .
http://members.ii.net/~ebeattie1/32m...table%20oc.JPG
And this is all i could get max (unstable).
http://members.ii.net/~ebeattie1/cur...0best%20oc.JPG
Im really dissapointed because all the other EPAW's seem to be getting 2800mhz. :(
