don't have multimeter....
its the board for sure - my pcp&c 510 sli reads low on the 12v line.........
This board defo read voltages low in the windows software. ITE says my 12v is at 11.78-11.84 but a multimeter says 12.16v solid as a rock with a PCP&C SLi.
that worked, thanks!Quote:
Originally Posted by pudds
:toast:
that sound great...couldnt really understand 12v being so low and other rails at their normal place....but my gf6800GT tells me its 72-74 degrees....with a nvsilencer5 mounted...i have hearrd something about DFI also corrupting those readings a bit....
I mentioned the problem above.
It's ridiculous that they don't calibrate it right or use another chip.
My case is not so simple .
dfi ultra-d , bios 02/09 , winnie 450
Mobo is on the table near the window , I put 3 fans 90x90 on memory, cpu and NB
i did the same test with opened window max cpu temp was 29C ( max 16M 9x306 1,55V 9x308-1M )
and closed window cpu temp about 43C (max 16M 2792 and even 2823mhz-1M )
whats going on
thats the result with closed window
http://img.photobucket.com/albums/v3...64/chujwie.jpg
Is there any temperature issue ??? why load cpu temp 43C is more stable than 29C ????
I have my dfi ultra
NB is a 0451A3
My dfi has had no problems
Guess I am lucky
Problem:
The FAN of the chipset cooler, runs slowly and then eventually stops.
Solution and prevention:
Connect the chipset FAN directly to the PSU :).
My NB temp was 42°C (full Load) before, and 36°C (full Load) after connect the FANs directly.
What's the problem about 42°C NB temperature? The fan is temp. regulated and does only run at full speed when the temp reaches a limit which you can set in bios. When the temp falls below another limit, the fan will stop spinning at all. That reduces the noise level dramatically.Quote:
Originally Posted by KaEL
Yes I know, and for 24/7 is OK, but for OCing and to feed it with more than 1.7V Full is better.
Who cares for noise level when you are doing serious OCing. ;)
BTW, on this MB particular, when it stops, doesn't always turns again. :confused: chipset temp is above of BIOS Settings (Stops FAN speed at certain temp).
522.2 is my best fsb with 4x multiplier
508 with 5x
not bad
tomorrow I'll try again my BH-5, I tested with a TRTW at 1 and only 271 with 3.55-3.6v
next tests with 2 or 3 and I hope 290
hope to see some nice BH-5 action again :)Quote:
Originally Posted by cpulloverclock
Odd that the load temp is more stable. I actually had two Raptors that wouldn't boot on a cold day in my room (8°C) as the connectors weren't tight anymore. But when running cold is great usually - a winnie issue perhaps?Quote:
Originally Posted by wampir
my ultra-D slowly died on me. It happened where it would'nt be stable with TCCD in it. SO i ran some cheap ram in it at a 1:2 divider. Then that stopped working, so the only way now it boots with with 1 stick in Dimm 3(going away from CPU). So i'm going to be RMA'ing the board. The problem just started to creep up on me, then finally it just refuses to boot anymore. tried 2 different bioses, one of which was an official 3/10. suposed to fix memory in-compatibility. but that sure as heck isn't working.
Sucks because my CAA2C newcastle is able to do 3.15ghz on my prom.
Sad news, Skip. I truly feel for you. :(
ya man that sux:(
Bad news man, sorry :( Hope your RMA flies through fast!!
If you don't mind me asking, how many lights are lit when you try to boot and it won't? Have you checked Vmem on the 1st DIMM with a meter? (and Vcore anywhere?) If I posted up a pic with two spots to check with a meter, and you still have the board, would you mind measuring the V at them? If not, no problem bro :)
Oh... noticed the prommie comment... silly Q... if you were under Z on that board, you try a good, thorough dry out?
Best of luck and OC's with the new one :toast:
well it is gonna fly through fast, cuz i second day aired it yesterday, with early AM delivery, so they will have it tomorrow morning. so if i'm lucky, they'll have it shipped friday, which if my previous newegg RMA's are any indication, they will have it shipped by then. So i should have it back in my hands by tuesday maybe.
Also, it didn't have anything to do with the prom, i always have a stock cooler handy, so i did give it a shot with the stock cooler. But the problems were there before i put it under a prommie. It stopped working with memory clocked higher than 170mhz when it was on air. there were no condensation problems either. But just for my sake, could you post the measuring points? as the only thing i currently do with my voltmeter is just check my powersupply. I'd like to know the readpoints on the board for future reference.
On the lights: At first, it would hang at 3 lights, then got past that with 1 stick in dimm3 (from CPU). booted fine with the 1:2 divider off 320MHz. Then i got it under the prommie, booted fine again at the same 1:2 divider. but tried my gskill at 1:1. worked fine for like 5 minutes, enough for me to get a 27sec superpi. then stopped working. And refused to work with anything in the orange dimms. never tried yellow, because it would never let me boot with that anyways, gave some warning.
but when it finally had it, was when i had it in dimm3, and it would start hanging then, right before it was supposed to back up cmos. with 2 stick in, it would hang on 3 for a while, then start over and work, but hang on the post screen. So something was really funky with that board. i hope i get a winner back. I also ordered 4x512MB of the twinmos stuff, not the SP. it was 103$ per GB, i couldn't pass it up!
Thanks Skip :D Follow me over here for the pics ;)
Ok so I got rid of my A8N-SLI Deluxe before even installing it. I am looking to some fun with this board ;)
Sudden-Sold-Syndrome, eh Ivan? :p:
My DFI LanParty NF4 Ultra-D runs smoothy with GSkill LA's TCCD 440 at 300MHz with 1T on Dual Channel, BIOS 217, slots 2 and 4, SP2004 stable.
If you try slots 4 or 3 alone... the system won't boots.
BTW I'm using a 20 pins PSU :)
EMC2
Sort of like bought-for-cheap-didn't-think-it-was-such-crap syndrome. I hate ASUS [K8V, K8N-E and now this] They make substandard boards for o/c'ing.
300 7-3-3-2.5 1T, or..?
