You know, I bet he did. :brick:Quote:
Guys don't fret. We've been making this ram for only a week so it will take time to fill the market. Just think...the time you wait may also see the prices drop which is good for everyone :)
price drops is good.. how about improved yields with better performance? A possibility or will the next 3-4 batches all perform the same?
yep online...got friend in south carolina-usa who purchases me stuff online...doubt he has any fry's store in 15-20 miles radius around :(
steve why your location is tallin ?
gimme her email please :D
Yeilds may get better, but I have no data on that kinda stuff. My location is Tallinn because that is where I live :)
not playing well with my AV8 and winnie...
265x9 fail P95
260x9 fail P95
255x9 fail P95
250x9 fail P95
1:1
222,10,12,16 @ 3.4V
booster in 1 or 2, mem in 3&4 (still need to test B=4 M=1&2)
would love to try higher V but mobo (MBM too) wont read >3.5...(ill be trying 3.6 on booster soon)
but remember this is a mobo that wont get BH-5 over 225 @ any V or timings
PS this wont be a very productive night but ill see what i can do...just wanted to put out the "first trys..."
Joe , Do you have another board ?
well I guess if you could only get 225 with BH-5 its not bad
Also please try 2.5-2-2 @ 3-2-2
Wow alot has happened while ive been asleep... Good to see more benchies coming through..
Acidbaby, waiting on your new overclock without .5 multi
As for me VX, its cleared customs at LAX and should be departing shortly.. ETA Monday ... Sunday(US)
Originally Posted by Joe Camel
Drop the multi another notch and try again mate. I suspect it's the mem controller needing voltage. Dropping the overall clock should have the same affect. I can't prime at 230x10 with ram at 230, but can if I drop the multi. I think everything with these winchesters comes down to this controller. If you're on water and can stick silly volts through the chip, cant see why you shouldnt be able to do well.
I bet it passes memtest doesnt it?
HTH
Oli
Can someone clarify trans am's question about bios vdimm setting when using booster...
ie. default 2.6v or auto?
either one will work
cool thanks.. I have always set the vdimm to the highest supported by the mobo then increased the booster... so wasnt it working correctly then?Quote:
Originally Posted by ryanpgroovy
wow i may be able to oc this further then
Noticed that Acid baby is using 2 sticks of 512 at once in that DFI board ..
I am having mixed results with the VX so far. I can't boot into windows at anything over 240x10 2-2-2-7 1T. tried volts from 2.9-3.5 my cpu is very capable of 2.6 and I can run my el4200 plat dual channel at 2.5-3-3-7 1t 280*9 3vdimm. However, I can use clockgen and agp/pci is locked. I can increase up to 260*10 and my best superpi was 32s 1m run. But when I tried to take screenie, I opened paint and system froze. Now I need ocz help. what is the best options right now? i've tried tras of 6, 7, and 10. Does tras 10 stress more than 6? I thought it did. see my sig for my testbed. Even trans am gets stuck sometimes. lol
I would try 2-2-2-10 , then 2.5-2-2-10 some people had luck lowering the Cas to 2.5 or 3
also I would work them up slowly , Thats the same thing I have seen twice now , went up to 240 to begin with and then after a while they could go up further.
I would stick with 3.3 volts for the time being and play around there
sounds good. Oh, I forgot to mention I was memtesting memtest86 ver.3.3 test 5 and had ram set to 250 and 260 2-2-2 3.3v and passed 1st loop, immediatley after beginning loop 2 the program freezes and had to hold reset button. This is odd since I would expect to see errors instead of just freeze during tests. ANyway, I'll try setting to cas 2.5 and trying agin.
burn in for Gold VX helps http://www.xtremesystems.org/forums/...554#post618554Quote:
i'm doing my burn in on P4 first hehe
Yeh burning in the ram makes a real differenceQuote:
Do you reccommend burning the ram in @ stock or at a reasonably high oc'ed level like 250mhz 2-2-2-10 for VX?
Follow his link ;)Quote:
i just burned inb for 4.5hrs and having the same results as trans_am :confused:
no matter what i do i cant even get 250 mhz!
Uh oh :(
Slightly depressing... maybe something else is causing the issue. Did you try 2.5-2-2-10?
When using the booster we usually just set the DDR Voltage to default and tweak from there. I does not affect performance if for some reason you would like to set the DDRv to 2.8 or whatever.Quote:
Does this help?
What voltage are you running?Quote:
Originally Posted by aCidbAbY
yes depressing that is... SC or DC?Quote:
yeh thanks, thats exactly what i wanted to know :)Quote:
Originally Posted by andyOCZ
