Hi, I just got my Neo2 working and so far My current specs are:
3000+ @ 2430
1.525 vcore
2.5-3-3-6-1t
Can anyone tell me how to host images, I was going to post a cpu-z screenshot. Thanks
3000+ @ 2430
1.525 vcore
2.5-3-3-6-1t
A bit over 300 HTT my system refuses to run any other MEM-divider than 100MHz, happens also with low MP's... :( This is running 1,76V, not 1,45V as CPU-Z shows:
http://home.no.net/comerade/pc/super...00_362x8,5.png
xit, very very nice Kamerat!! whats the week and code after??
0447UPCWQuote:
Originally Posted by CyberOps
Just replaced the pos fan on my thermaltake silentboost with a vantec tornado and my CorsairXMS 3200 with PatriotXBL 3200 today and finally made it to the 2.7 club! :toast: I'm having to run my new mem at a 166 divider cause I can't get it to do 300MHz @2.85v on my Neo2 Plat. Anyone think the OCZ booster on the Patriot 3200 would get me up to 300MHz so I could run 1:1?
Anyways here's my OC...HalfLife2 tested Gamer approved! :D :banana:
Buy the memory wtih TCCD and brainpower PCB ;)
This is my setup wtih 2x512MB OCZ 3200 platinum rev.2 with TCCD ;)
Code:http://www.bbpix.com/pix/A64@2700MHz_300HTT.jpg
MSİNEO2PLN. 3200+@2740MHZ(CBBFD 0433SPMW) RADEON9700PRO/2x512TWINMOSDDR400@550MHZ (1.5-2-2-1)
wat kinda cooling is that osipower??Quote:
Originally Posted by osipower
EDIT: also is that stresscpu/prime stable??
air coling & hyper6
stresscpu/prime stable ok
thats awesome...i just picked up the same stepping cpu, hopefully it is as promising as your result :)
One nice overclock there, osipower!!! :toast:
Those 0433SPMW are beasts. And easy to find here :toast:
osipower more vcore! =P
Damn and i still cannot find any older than 50 week :(
Osipower - nice cpu :toast:
vcore 1.6vQuote:
why, the 50th week stinks?? I've 3000+ 0451 dpaw and hope to have a good clockerQuote:
Originally Posted by Adasi
Couple of my friends had them and their max clock was about 2500mhz...
From I've seen they're very average ocers.Quote:
I got a week 50 ABPW.
Topped out a 2.6.
Week 48 SPAW here at 2745 at 1.58v.(need more vcore :mad: )
0450APBW
It can go up to 2.6GHz, but I need 1.65v :(
http://xtremesystems.org/forums/atta...chmentid=23121
http://www.hot.ee/razor/2500mhz.jpg
0437, 1.425V from bios
MSI K8N neo2
2*256 TCCD
passive watercooling (no rad.)
Originally Posted by chainhoe
how did you lower the multi to 8.5 ?
you cant set it to 8.5 from bios?
I thought they were locked?Quote:
EDIT: wow, the lower multis are unlocked! I just changed mine to 8.5, I am such an idiot :p:
Its not as good as your heavy duty machines but well..
http://img33.exs.cx/img33/6232/264815845nd.th.jpg
Winchester 3200+
ADA3200DIK4BI
CBBFD 0435 XPAW
1089917I40485
Msi Neo2 Plat
1x512 Nanya (suxxx) pc3200
C Ya
