Just switched from a P160 to the 900. I also posted this in the 900 review thread. Here is what I got after some cable management :)
http://img239.imageshack.us/img239/5...open900ry0.jpg
http://img358.imageshack.us/img358/5...osed900uz1.jpg
My first air cooled rig in a longgg time...
http://upload.nickfire.com//files/13...28Large%29.jpg
Front: Yate Loon DSL12L @ 7v
Side: Yate Loon DSL12L @ 7v
Rear: Yate Loon DSL12L @ 12v (LOUD.. ok maybe not but not as quiet as I'd like)
CPU: Panaflo M1A @ 7v (Some bearing noise but its definitely tolerable)
GPU: Arctic Cooling Accelero X2 (PWNS, got it @ 27% 2D, 100% 3D and I can BARELY tell the difference. Keeps the card under 70*C @ 700/855)
Chipset: Evercool 40MM @ 7v
my (not yet completely final) secondary system:
http://img85.imageshack.us/img85/4295/img3794oi3.jpg
http://img141.imageshack.us/img141/180/img3793yq2.jpg
hardware:
opteron 146 @ 2.5 ghz @ 1.375v (primestabil)
dfi lanparty ultra-d
1gb kit g.e.i.l. @ 180 mhz by 2-3-2-5 t1
asus en7800 gtx with ac silencer
edit: a realy nice picture of my 7800 gtx :slobber:
http://img254.imageshack.us/img254/8128/img3773mf4.jpg
Its been a while and i keep an updated post in this topic at #376.
But i felt like i should post some new pics. :p:
http://members.home.nl/william28/PC/...4-02-07_th.jpg
I finally decided to put my zalman FS-C77 back on and took the time for it.
My dothan is now 38 degrees stressed @ 2,4 GHz. :)
http://members.home.nl/william28/PC/...-02-07_th2.jpg
:D
Some pics of my new air-sys. it is the new sythe samurai master.
http://img177.imageshack.us/img177/6726/scythe1dj2.jpg
http://img177.imageshack.us/img177/7415/scythe2lw6.jpg
http://img223.imageshack.us/img223/2530/scythe4cg9.jpg
Scythe-sisters :stick:
http://img223.imageshack.us/img223/6950/scythe5ac3.jpg
http://img257.imageshack.us/img257/2609/scythe6ze9.jpg
http://img293.imageshack.us/img293/3385/scythe7xn4.jpg
in Action :banana:
http://img293.imageshack.us/img293/6236/scythe8wu7.png
select, that cooler any good?
well heres my setup, notice the strategically cable tied fans over my chipsets lol. Im quite happy at how tidy it all turned out though.
http://img521.imageshack.us/img521/7612/dsc00414ng1.jpg
i like him, the temps are on the level like the ninja, maybe a few degrees higher (2-4°). But i must use these cooler, because the ninja blocks the ramslots and i want to use all 4 of them.Quote:
Originally Posted by Origin_Unknown
i really love your lcd, is that the 3000:1 contrast version?Quote:
Originally Posted by TheGooch
A few impressions of my lovely main system :D
http://img441.imageshack.us/img441/483/dsc00014au2.jpg
http://img390.imageshack.us/img390/9830/dsc00224we3.jpg
http://img390.imageshack.us/img390/3346/dsc00056bl7.jpg
http://img390.imageshack.us/img390/1266/dsc00241ci0.jpg
http://img441.imageshack.us/img441/4973/dsc00062hu2.jpg
Tommy_Hewitt what case is that? And no ramsinks on your X1900XT...?
A Lian Li G70 B with a Lian Li PC-71 Windowkit.
http://img240.imageshack.us/img240/143/dsc00011vp6.jpg
I love this Case. Much space in the inside and you can mount many 120mm fans. Vvery important for me, cause I'm a silentfreak :D
The RAMs of my X1900XT aren't very hot, so I don't need the RAMsinks ;).
OK I wasn't sure on the RAM, I have the X1900XT as well and I've heard both "no you don't need ramsinks" and others saying "yes you do" so I thought it would be best to just play it safe. But then, I guess you do have that fan blowing down on the ram so that probably helps quite a bit :)
I think GDDR3 don't need much cooling. Maybe, when you overclock a lot.....but mine only run at 800Mhz (1600Mhz) :). And the card still works great. The bigger problems are the PWMs, they get (or become? Sry, I'm not very good in english ^^) really hot. Sometimes 90°C and more
http://img522.imageshack.us/img522/9553/img3757xq6.jpg
money for an better cooler is out, but on the next weeks it's be perfekt.
Originally Posted by deepsilver
which mobo is this
cause i don't remeber any dfi nf4 mobo with weird places for Sata cables
and i think u better plugin the 4pin connector on the mobo more more stability
Mobo is a DFI NF4 Ultra-D. The Sataports aren't placed weird, why do you think so?......and you only have to plugin the 4pin Connector when you use SLI
deepsilver your cable managment reminds me of my case :p:
He has a PCI SATA controller card in that slot, that is why some of those cables go over there.
Tommy_Hewitt, my vregs on my X1900XT rarely get over 65 C, but the cooler I have on there cools them really well. But my core runs hotter than yours does I'm sure so it is a tradeoff I guess.
the board is an dfi lanparty ultra-d, but the satacabel are ok (i thik). :DQuote:
Originally Posted by SaFrOuT
the connector by the board is only by sli or dualgfx necessary. :)
its 2000:1Quote:
Originally Posted by Drag
heres the original pic though
http://i33.photobucket.com/albums/d6...2/HPIM2662.jpg
Vregs are PWMs, aren't they? If yes: 65°C are really good. Which cooler do you have on them? How many ° has your core? I have 68°C load and 37° Idle, but i would prefer cold PWMs to a cool core.Quote:
Originally Posted by SparkyJJO
Yeah same thing, vregs, PWMs, whatever, I got used to typing vregs so it comes faster for me :p: OK stupid reason I know.Quote:
Originally Posted by Tommy_Hewitt
Anyway I'm using the Thermaltake TMG AT1 cooler. Basically a ripoff of the arctic cooling silencer series, only made to work with the X1900 series which arctic cooling failed to do (they came up with that accelero thingy instead).
Here is a little review I did of it. Warning, it is picture heavy, so it has a 56K warning. My first review, probably not the highest quality one, but it gives you an idea of what it looks like and how it performed for me. And I was wrong, the vregs/PWMs got to 66 C not 65 C but no big deal, 65 C was an easier number to remember :p:
Hey, I've already read your review. Nice shots of the card. I like the cooler, looks gread, but the HR-03 is also a very beautyful cooler :)
Back to topic. Looks great but makes lots of noise xD
http://img45.imageshack.us/img45/2166/dsc00131vl3.jpg
My air cooling case :D
*The modding project is not finish*
