Guys, I have a weird issue that I get when using my KVM but only when my Gene-V is plugged in. My KVM is an Aten 2-way DVI USB KVM with 3D/120Hz support, if I install it the way the manual/labels say then I get boot straight to bios with kb ( Razer Lycosa)showing in bios but it works only intermittantly, the illumination flickers wildly as if the usb cable is being plugged and unplugged randomly. If I use the mouse port my mouse can not move the cursor. So if I plug the kb and mouse direct to mobo it all works properly. I just RMA'd this KVM for this issue and the new one is exactly the same, any ideas what it might be?
