Issues with BLCK adjustement/X79 Sabertooth/i7 3820
Hi
I am trying to determine if I have a faulty X79 Sabertooth motherboard. I was hoping if someone out there with the same board could confirm if they are experiencing the same symptom?
Basically if I make any BCLK adjustment above 100.5 when I power off the power supply completely (draining all power to board), when I next turn on the board starts briefly/stops/starts again (almost as though it was going to produce an overclock failure) but then proceed to run normally at my designated overclock. This only occurs when I increase the BCLK above 100.5 AND power off supply completely, a standard shut down does not produce this.
My highest stable overclock of 4.6ghz using BCLK 121.75/CPU STRAP 125/Multiplier:38 runs fine but continues to have this symptom. However if I bump the BCLK up to 125/CPU STRAP 125/Multiplier: 37 (to produce a similar clock speed of 4.6ghz), I have the same problem but this time the board DOES produce a overclock failure when booting after a power supply turn off. No amount of bios adjustments or tweaks seem to get this one stable.
As I understand it the bclk is a little sensitive with this x79 chipset but I was curious if perhaps I have a bad board. I dont remember having any of these issues with my old X58.
Any input from other sabertooth users? I have posted on another forum but did not get any response from sabertooth owners. One guy with a MSI board reported something similar.
Motherboard: ASUS X79 Sabertooth Processor: i7 3820 @ 4.6ghz Memory: 16gb (4x4GB Samsung MV-3V4G3D/US
P9X79 PRO Problem Upgrading to BIOS 2104 Using CAP Converter
I was running BIOS 1203.ROM and upgraded to the 2104 using the CAP converter. All seemed to go well, the machine rebooted a number of times and then into the BIOS. It showed 2104 so I thought all was good. I then saved and exited and the machined re-booted and I got a message "Bad Disk". I tried to reboot into BIOS but it kept coming back to the error message.
Luckily I am paranoid, so I had already purchased a 2104 BIOS chip from the ASUS eStore. So I pulled the chip and replaced it with my ASUS pre-flashed chip. Same thing happened again! Got the bad disk error and could not get back to BIOS screen.
So, I pressed the Clear CMOS button and the machine booted normally. I was able to enter the BIOS screen and make some changes and the machine rebooted normally into Windows 7.
One problem: the Q-Code display is permanently stuck on "04" - but this cannot be a real Q-Code because the machine is fully functional and runs normally. I contacted ASUS tech support and they said not to worry about --LOL!
It appears the Q-Code display is locked up and no longer functions. Any ideas on how to fix it? I am reluctant to do anything because it is not causing any problems. Has anyone seen this behavior?
Thanks...
