Voltage tweak support from ASUS
http://i237.photobucket.com/albums/f...GTX480volt.jpg
Source
Source
thats why : http://www.guru3d.com/article/radeon-5830-review/15
unigine and far cry 2 its like they are trying to master in those games
asus probably expects you to reach 900 mhz lol
Guru3d results are alot different than hwcanucks results.
http://www.hardwarecanucks.com/forum...review-16.html
The gtx 295 is losing to the 5870 here and the gtx 285 loses quite handily.
I am a bit sceptical about those recent graph results. If the gtx 480 was that fast in the first place then we would seeing leaks long time ago. In addition, the gtx 470 should be as fast if not faster than the 5870 looking at those results. But the 349 price seems to indicate it is slower.
But then again results like that is still below the hype fermi initially promised.
I just wanted to reply to you guys, to explain :up:
In Crysis the US Team Plays against a North Korean team, this was the intended 'Pun'
answer as above, and also i woke up years ago, to Bigotry and racism, i have also traveled the planet to many differant cultures and races. and loved them all.
so please dont tar me with the Racist brush
if i was truly racist, the wonderful mods would have locked me out for it, thankfully they have the wisdom to spot real trouble and racism.
i am of course neither
what happens in your country as regards to the segregation of asians, troubles me if true, but then again so do children starving in africa.
thank you for your support Golden Tiger, you are correct in seeing i am not a racist and i have never been.
the problem lies herein (in bold) our perception of racism (but this is not the place to discuss it.)
so thank you i just thought i would explain a little :up:
back on topic
now we have voltage tweak on a supposedly bad overclocking card that runs like a furnace? this should be fun for the air guys out there, i expect a few RMA's lol
lucky im on water :D
:) Yeah, not the place but you clearly aren't trying to stir things up or anything.
I find it interesting too on the Asus voltagetweak thing slapped on the box... either they're going to have a LOT of RMA's from noobs, or the card isn't as hot a furnace and poorly overclockable + performing as we've been lead to believe...
thanks :up:
just found this on my travels, i went to the nvidia site and it has been pulled, things to come?
http://img291.imageshack.us/img291/3650/38875357.jpg
Does this really mean i have to wait another 6months for the full 512SP GTX485? :/
(Data in table http://www.hardware-infos.com/news.php?news=3484)
well gurus are newer. i recall nvidia gaining 20 or 30 percent in far cry 2 with newer drivers correct me if i am wrong and to say the truth i expect gtx 480 be much faster than 5870 in nvidia favored games. weren't first fermi videos showing great performance in far cry 2 anyway ?
I'll tell you something about Far Cry 2 benchmarking.
Both ATI and NVIDIA have built in FAR too many optimizations into their drivers for the standard "Ranch" benchmark runs. That's why we avoid it like the plague. Our results are based off of a 10 minute gameplay sequence. The "Ranch"-based benchmarks used to be quite accurate....not anymore.
The game itself is currently somewhat ATI-biased simply because their drivers have improved Dunia Engine performance drastically.
Since we don't know where those benchmarks are taken from within the game (Ranch sequence or in-game), it's best to take that with a grain of salt.
HOWEVER, for NVIDIA to be performing that well in DiRT 2 (a game developed with the close participation of AMD) is a huge step in the right direction.
well avgs are low so i bet they again picked 2560 res for bench which can explain 480s nice performance in dx11 and btw guru also benchs with gameplay sequences
Good points... I had the same thought on Dirt 2 myself.
I run 2560x1600, so to me it is extremely important that a high-end card can perform at high-res. As far as the avg's being "low", the minimums are important to me, in fact what drove me to buy a 5870 over my then-current GTX 280 even though the averages weren't as spectacularly high like the minimum gains were. As SKYMTL said of course, can't really judge a ton off of the FarCry 2 bench there without context, but if minimum gains like that turn out to be the norm in real benches across review sites, then it would be a smashing success of a card: I don't care if it can spike to 150fps while maintaining a 60 average... I care if it can stay above 45-50 while maintaining a 65-70 average, even if that means the max is only around 100 then ;). Max framerates and by extension averages can be easily skewed with that.
That makes sense. So skymtl, I am not asking you to break NDA, but assuming you got a GTX 480, are you disappointed with testing so far or impressed? Don't have to mention power or performance, just your thumps up or down.
Good showing in DiRT2, although not enough info on the settings, but 20% up on an ATI happy game is not bad for early drivers.
Cool.
I highly doubt he can say anything either way, but good try! :p:
Voltage tweak means nothing ,65nm gtx200 cards had it as well,improved overclocks about zero.
Olivon , xbit only measures wattage supplied by PSU vie PCI-e power cables , as far as i know they do not measure wattage supplied by PCI-express slot , which is up to 75 watts .So take those graphs with a grain of salt .
