ZEUS:how much voltage foir this crazy NB? Nice... 2700 MHz at NB for R11.5
I think it was 1.3 or 1.31V set with EVO TurboV so in reality closer to 1.33-1.34V with this board's overvolting nature. It still felt pretty stable, in cold conditions more should be possible i think. ;)
Will join u guys soon with a score. Initial run is 7.03 but this puppy still has legs...
Just did a rerun same setting except for higher priority 7.24
Nice score!:clap:
EDIT - Top 15 (up to post #668)
Code:Name /Post# Score Cooling CPU MHz ScreenShot
01 VoodooProphetII /328 10.45 LN2 X6 1090T 6026 01
02 FlanK3r /647 9.57 LN2 X8 FX-8120 5885 02
03 FlanK3r /391 9.36 LN2 X6 1100T 5418 03
04 I.nfraR.ed /376 9.18 DICE X6 1090T 5134 04
05 AMDnord /359 9.14 CASC X6 1090T 5124 05
06 Dumo /461 8.85 1-Stage X8 FX-8150 5418 06
07 Daveburt714 /582 8.84 H20 X8 FX-8120 5389 07
08 Zeus /660 8.72 H20 X8 FX-8120 5298 08
09 equinox1 /445 8.72 H20 X8 FX-8120 5331 09
10 krjalone /556 8.65 H20 X8 FX-8150 5310 10
11 equinox1 /303 8.60 H20 X6 1090T 4875 11
12 Barr3l Rid3r /668 8.60 H20 X8 FX-8120 5220 12
13 I.nfraR.ed /621 8.57 H20 X8 FX-8150 5226 13
14 BeepBeep2 /659 8.53 H20 X8 FX-8150 5224 14
15 Asmola /618 8.50 H20 X8 FX-8150 5168 15
Well, here's my score so far. Can't get to boot yet with 5ghz
https://photos-2.dropbox.com/i/xl/UF...h%204.7ghz.jpg
Where's my score??? I have a score of 11.50 with a AMD 12 core Magny-cours. Its post #502
Its a ES so no model number. Its a single socket G34 setup with 8 gig of ram when tested. Its on air but even with better cooling, I have hit the max for the voltage reg on the mother board so 7 cores at 3.3gig and 5 cores at 3.6gig.
It won't do more...tried up to 1.61v.
PSC are pretty nice...2500 CL7 :rolleyes:
I really need to get rid of this CPU.
http://img97.imageshack.us/img97/2660/5224cineweb.png
Not bad Beep. Not bad at all.
I'm wondering what temps you got there for ambient.
It tried too tonight, got arond 1ºC ambient tonight but my chip just isn't cutting it.
Here's the very best i could pull off:
http://img.photobucket.com/albums/v6...15872small.png
Dave, your chip is so much better dude, you just don't know how lucky you got this time.
No way i will beat that score, not even with temps below zero i think.
I tried up to 1.59V, prett7y scary volts for 32nm but the CPU survived.
Wow, I'll never be able to match that...
I still can't break the 5.0 barrier in normal ambient, nonetheless -4c ambient outside helped a bit.
I'm a little weak to be carrying my rig across the house and outside, 16 year old with weak upper body :rolleyes:
1.52v like Dave uses doesn't even post past 5.2 at -4c ambient :/
Subzero will bring more fun to FX
I'll update post when I get home with ss,
Best Ive got yet is FX-6100 4.9Ghz cinebench 11.5 score:6.01
I feel so out gunned buy all of you with FX-8150/20's
I have done my first Cinebench run is this done correct?
I have no clue how to bench it.. the first 20 times the machine froze on my even at stock settings! untill i found out that i just should let it run then the score popped up LoL..
http://i438.photobucket.com/albums/q...toft/cine1.jpg
Here is the full pic.
Update with screen shot. now if I could get 4.9Ghz stable
http://i75.photobucket.com/albums/i2...sus/49cpuz.jpg
Yes that is ok Riska but the CPU frequency is far too low :D. If this is your super CPU then cranck it up and show us what it can do in Cinebench man.
Barr3l, nice run, seems a good CPU. What ambient temp and what cooling?
It is low on cpu because cinebench froze evry time i pressed run and i clocked the cpu down but realysed that i just have to wait for the run to complete
Wil run again tonight with higher speed
teaser :p
http://www.hwbox.gr/images/imagehost...aa6a3ae7f4.jpg
thats fully untweaked (mem,NB etc) just testing the cpu :D
Lol, yes, it starts with a small black square in the middle of the screen.
@Barr3l: Looks a promising CPU if it can do 5.2GHz with such temps!
@RekcOlNu: Thanks for updating the chart man.
@AMDnord: If that is a teaser, i'm looking forward for the one you are about to post! :eek:
I have H2O
My water setup is Xspc Raystorm and 11.1mm tube a laing DDC 10w pump with Xspc res/top on it and 2x Xspc RX360 radis in on loop i always have 20-22c in my work room
