My sticks is getting 1.7825volts and they have never gotten more than that. On my Rampage black edition with my 980x id did nearly the same speed at same volts
Crosshair V Formula is overvolting Dram quite a bit, real voltage on the rams was at least 1.8V i guess. Never the less, very impressive frequency for 6-6-6 timings.
any thoughts about this kit for BD?
im looking for 16gb kit (for eventual 95w 8120 bd which I dont have yet).
Difficult to decide if I'd use Gskill Eco for OC and use any cheap 16gb kit for workstation hmm. psc, hynix bfr?
DDR3-2585 9-9-9-28 in dual channel with GTX2. Didn't push hard, but I bet 2600+ is possible. And this on CHIV :D.
Not sure if possible with current bios. Tried hard at 2285, but couldn't manage to run Prime95 error-free for more than ~10 minutes.
I think the IMC craps out or the divider is buggy. Same with the Trident kit, which validated 1330MHz, but I reached the CPU-NB limit. Really need other mem dividers (highest now is 1866).
The 1.7825volts are measured with a DM and it is set at 1.725 in bios
Thanks Leeghoofd! :up:
I just ordered a set of these (hopefully it's the same kit :p:), they're on sale at the Egg for $70 w/discount...!
http://www.newegg.com/Product/Produc...82E16820231476
I didn't read this whole thread so if you don't mind would you post your best clocks (or link it for me)...
Thanks, Dave
The King
http://i39.tinypic.com/2qkttag.jpg
Patriot
http://i43.tinypic.com/2b3clc.jpg
As Talentosas
http://i42.tinypic.com/208i338.jpg
Well, I finally got these Ripjaw 2133's today. I haven't had much time to play with them, so these are really early results. ;)
So far, I kind of have mixed feelings...
The clocks are really good, but I'm having a hard time tightening timings.
Maybe it's just the nature of an 8gb kit, but my old Mushkin Lovos (4gb 2x2) were killer and did 2040 @ 7-10-7 stable.
Anyway, heres what I've gotten after a few hours (seemingly stable):
http://i30.photobucket.com/albums/c3...133RipJaws.png
It's a nice kit for $70... Guess I was just hoping for a little more as far as timings go. :p:
I obviously have alot more work to do, but I'm just looking for opinions... ;)
4gb density says it all...
Do I have any chanche for 2133MHz on BD with the below four modules?
http://i41.tinypic.com/110vcs1.jpg
Hypers, yeah I should think so.
I got me a kit of Gskill Tridents 16000 C9 i planned to put into my mom in law's computer but after testing i think i am gonna keep them myself:
http://img.photobucket.com/albums/v6...mtestsmall.png
I think 500% HCI memtest can be considered stable.
I tried higher but it errored, more volts backfired badly, 165V in bios which is approx. 1.675V real seemed to be the sweet spot. It booted at Trcd 8 but it wasn't even remote stable.
From what i've read these babies should contain Elpida BBSE chips.
Only paid €60,- for this kit so not too bad i think. :)
Very nice.
better BBSE was able to pull just about 2000 7-8-7...
I'm eying a Team LV kit, 2000 9-9-9 ;)
Thanks.
I think this kit can pull that off too but not stable and i prefer to have my ram fully stable to avoid a corrupt OS.
I tried DDR2000 7-8-7 with 1.625V in bios and it did boot but once i tried to set trcd back to 9 and tried to save and exit it frooze. Some more volts will get me into Windows i'm sure but not as stable i would like.
very nice RAMs here...I dont tried much some max RAMs at FX, for daily use Im at 1134.5 MHz( so 2269 MHz) 8-10-8-28-44-1T
It seems to me that GSkill is doing a pretty tight binning process for the ic on their kits. I think the good strong clocking ic are binned and held for their more expensive offerings. Their more pedestrian everyday kits seem to perform up to spec along with perhaps a nominal overhead.
I bought some cheap (on sale) 2x4gb Gskill Sniper 1866 kits (9-10-9-28-2T @1.5v) and they don't seem to tighten up very much or for that matter overclock all that well... i.e... 2133 with more relaxed timings while raising the dram volts to ~1.65v. I'm currently running 16GB at 1920 9-10-9-27-1T with ~1.587v.
http://www.newegg.com/Product/Produc...82E16820231460
These are my initial impressions... I haven't had them for long or even tried them on my SB platform... so there may be room for further improvement. :shrug:
Adata2000G v.2 @2087 C6-10-6 1T :D
http://valid.canardpc.com/cache/banner/2130445.png
http://img151.imageshack.us/img151/9977/84666045.th.png
