Originally Posted by
carmatic
on mine, the LCD poster says that the mobo is 39 degrees, while speedfan's 'system' reading says 40 degrees
ambient temperature for me is 20 degrees
i've bought a delta fan for the summer...
also the temperature difference between my cpu 8 'cores' in speedfan has increased up to 7 degrees celcius when running prime... hottest pair of cores reached 57 degrees while the coolest pair stayed at 50 degrees ... i thought that replacing the thermal compound with artic silver would fix that, but it made no difference...
one more question, is there a way to get more control over what the LCD poster shows? i want to make it stop cycling through all 6 temperature readings and stay on the cpu
