If you have a 45nm cpu, you are aiming for the voltage given by the 0.635x multiplier, so to work out what to put for the the 0.667x GTL Ref (Y) values (it will be a negative number to make the resulting voltage the same as the 0.635x GTL Ref voltage), use the following eqn, but substitute the Vtt you use, in place of the example Vtt.
In the examples given, I have rounded off to 3 decimal places throughout for simplicity.
For me, Vtt = 1.14v
Equation:
Vtt x 0.667 + Y = Vtt x 0.635
1.14v x 0.667 + Y = 1.14v x 0.635
0.760v + Y = 0.724v
Y = 0.724v - 0.760v
Y = -0.036v
Y = -36 mv
So to verify it:
1.14v x 0.635 = 0.724v
1.14v x 0.667 = 0.760v
0.760v - 0.036v = 0.724v
or an easier, non algebraic alternative:
0.724v - 0.760v = -0.036v
= -36mv
So for me it is 1.38 (VTT) x 0.635 = 0.8763
